UE虚幻资源 [模型/材质] 墙面划痕损伤实例材质贴花虚幻4UE4 Customizable Cracks
816
1
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 材质|Shader
价格:50 元素币 百度网盘 收益:0元素币 销量:0
尊敬的游客 ,本内容需要支付后可见.
提醒使用【余额支付】需要: ¥5 余额
贴内素材收录在微库素材库中,即搜即用,高品质且方便易用!
链接:https://www.element3ds.com/plugi ... =4071&third=5788#pt
scene01a-1920x1080-357186a1d95b14b5bf1d00cffb309f30.jpg scene02-1920x1080-6479cb6941263f654b3d632918e7db93.jpg
Customizable Cracks includes 32 normal decals that allow you to make and customize masked grunge normals. These decal normals can be adjusted in surface area by adjusting the mask intensity in the material instance. Also included is a padding feature that adds extra visual depth to the surface damage in relation to its normal strength, which may also be fine-tuned to your desires. These decals make up an assortment of potholes, cracks, wear, and other surface damage that have a multitude of composed assortments. It is important to note that the master material requires your project to have DBuffer enabled in the project Rendering settings in order to render properly.
You can view the overview video here!
技术细节
Features:
Normal masking that can be used to adjust decal surface area via slider.
Color padding that allows you to add visual depth to the damage in relation to normal strength.
A variety of 32 different grunge decals that can be used to add high quality, custom made damage detail to your hard surfaces.
Texture Resolutions:
2048x2048 (all normals)
1024x1024 (all masks)
Number of Materials: 2 Master Materials, 34 Material Instances
Number of Textures: 68
Supported Development Platforms: Windows
Supported Target Build Platforms: Windows
Documentation: All appropriate documentation can be found in the Notes section of the Overview map.
Additional Notes: Remember that you need to enable DBuffer in your project settings, which can be found under Project Settings > Rendering.
参与人数 3 元素币 +40 活跃度 +15
君鱼  发表于 2023-8-16 16:33:03
G58735053G 实名
19 小时
学徒法袍 长剑 长枪
