程序化贴图 [sbs格式] Broken Tiles Tutorial - VOL 01 - Single User License-破碎瓷砖教程
2459
4
价格:53 元素币 百度网盘 收益:954元素币 销量:18
尊敬的游客 ,本内容需要支付后可见.
提醒使用【余额支付】需要: ¥5 余额
A站链接:https://www.artstation.com/marke ... les-tutorial-vol-01
How to make Broken tiles with fallen leafs in substance designer
Making the tile type material with extra details in substance designer with simple step, in this tutorial you just need to know basic nodes and how to blend them. In this tutorial, you can learn how to use basic node in substance designer to create the tile material type with extra details like fallen leafs in 245 minutes. Learning this technique can help you understand what you can do in the substance designer for the projects like thisUsing this tutorial, you need to know the basic fundamental of substance designer and its workflow.
Contents:
245 minutes unnarrated videos
1080 Resolution
Chapters:
01- First step: Creating Height - In this chapter we are creating our height and after that normal and ambient occlusion. At the end we have all Height/Normal/AO and details for this project.
Part 02 : in this chapter we are going to Create all data for BaseColor/Roughness/Metallic maps and at the end atlas data to final broken tiles and finalize our material.
Part 03 - in this part you learn how to create atlas sheet sbsar from quixel textures, and you can use this technique for any texture set you want
Software Used:
Substance Designer
Level:
Intermediate
Prerequisite Basic knowledge of Substance deisnger
Attention: clean SBS file are included in this product that you can study over that
Attention: all videos are unnarrated ( it means there is no voice-over videos or subtitles )
如何在物质设计师中制作落叶的破碎瓷砖
在物质设计器中通过简单的步骤制作具有额外细节的瓷砖类型材料,在本教程中,您只需要了解基本节点以及如何混合它们。在本教程中,您可以学习如何使用物质设计器中的基本节点在 245 分钟内创建具有额外细节的瓷砖材质类型,如落叶。学习这项技术可以帮助您了解在像这样的项目中您可以在物质设计器中做什么使用本教程,您需要了解物质设计器的基本原理及其工作流程。
内容:
245 分钟无解说视频
1080分辨率
章节:
01- 第一步:创建高度 - 在本章中,我们将创建高度,然后是正常和环境遮挡。最后,我们获得了该项目的所有高度/法线/AO 和详细信息。
第 02 部分:在本章中,我们将为 BaseColor/Roughness/Metallic 贴图创建所有数据,最后将图集数据创建为最终破碎的瓷砖并最终确定我们的材料。
第 03 部分 - 在这部分中,您将学习如何从 quixel 纹理创建 atlas sheet sbsar,并且您可以将此技术用于您想要的任何纹理集
使用的软件:
物质设计师
等级:
中间的
先决条件 Substance deisnger 的基本知识
注意:本产品中包含干净的 SBS 文件,您可以对其进行研究
注意:所有视频都没有旁白(这意味着没有画外音或字幕)
参与人数 6 元素币 +72 活跃度 +36
昕晨  发表于 2022-5-31 12:09:39
牛哇
MJ漫步  发表于 2022-5-31 21:22:16
感谢分享!!!!
UPyou  发表于 2022-8-16 11:23:52
思路很清晰 不错
張涵東  发表于 2022-9-29 16:10:56
天明浕夜a 实名
18 小时
长剑 长枪
