UE虚幻资源 [其它类型] 高质量屏幕截图输出管理插件虚幻4UE4 Screenshot Pro
205
2
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 其他扩展
https://www.unrealengine.com/marketplace/en-US/product/screenshot-pro
Documentation: https://bit.ly/33GsHK9
Support Thread: https://forums.unrealengine.com/ ... -pro-support-thread
Discord Server: https://discord.gg/7AUwnva7ge
Demonstration Video: https://www.youtube.com/watch?v=OUBrNFsDHVA&feature=youtu.be
Now supports Unreal Engine 5
Access via Tools > JKelly Utilities > Screenshot Pro
Supports Movie Render Pipeline
Screenshot Pro UI uses an internal preset for MRP
Use your own MRP presets via the settings menu
Screenshot Pro is an editor utility that acts as an all purpose camera manager, great for architectural visualization.
Screenshot Pro creates a paused instance of your scene at capture time at the specified resolution to ensure the highest possible quality, preventing the usual blurry artifacts when using the built in high res screenshot tool.
The Pre-Capture delay setting allows you to determine how many frames to accumulate allowing temporal effects like Temporal Anti-Aliasing and Raytracing to resolve fully. (This does not currently use the new Render Movie Manager in 4.25 but integration is planned for future updates.)
Easily rename your cameras - which in turn changes the output filename as this is based on the camera's name.
Quick access to the details panel of multiple cameras means you do not need to find the camera in your outline to edit it's settings. This applies to settings for both standard and cinematic cameras.
Technical Details
Features:
Render stills with Path Tracer
Batch Render stills from cameras
Supports Movie Render Pipeline Master Config assets
Rename Cameras
Pilot Cameras
Edit Camera Details
Code Modules:
ScreenshotPro (Editor Module)
Number of Blueprints: 10
Number of C++ Classes: 3
Network Replicated: No
Supported Development Platforms: All Platforms
Supported Target Build Platforms: Editor Only
Documentation: Yes
Important/Additional Notes:
There is a minor issue with enabling HDR capture in a running instance that prevents actually saving as .EXR. To get around this, when "Capture HDR" is toggled, Screenshot Pro will default to exporting GBuffer passes and save out only two passes: PostTonemapColor and PreTonemapColor. When "Export Buffers" is toggled this simply expands the number of passes that are exported to include the default list (BaseColor, Metallic, etc)
This tool requires that the "Editor Scripting Utilities" and "Sequencer Scripting" plugins are enabled.
There are rare instances where the pilot/eject button states fail to update. If this happens, click the refresh button and click either "Create New" buttons to resolve this issue.
喧闹任其喧闹,自由我自为之
wangzhenmo  发表于 2022-6-9 19:36:47
煎饺jianjiao 实名
煎饺
3 小时
短杖 火元素
