UE虚幻资源 [其它类型] 地形生成插件虚幻4UE4 Procedural Terrain Generator
213
2
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 其他扩展
https://www.unrealengine.com/marketplace/en-US/product/procedural-terrain-generator
The Procedural Terrain Generator (PTG) v2 is an editor code plugin that aims to assist the user by procedurally creating terrains with different shaped (plane, sphere or cube) and populate it with thousands of nature meshes (using HISMs) and actors in just a few seconds, using your own assets. It also provides modifiers and other settings that let you create exceptions on the terrain for certain assets generation. For example, you can use trees and grass assets, but configuring the plugin to avoid locating trees in a defined area or height.
TUTORIALS AND OTHER VIDEOS
Documentation
Example Project
Forums
Support: norlun5@gmail.com
Disclaimer:
It is not designed to generate infinite chunks of map on runtime.
The generated terrain is not a landscape actor, and therefore it CANNOT be edited with the landscape tool.
All the assets shown in the gallery and videos are from other asset packs and from the starter content.
PTG v2 is only available on UE4.26 and beyond.
Technical Details
Check the version notes here.
Main features:
Procedural terrain mesh creation using different noise algorithms.
Procedural water mesh creation with height customization.
3 different terrain shapes: plane, cube, and sphere
Tilable terrains (only available on plane terrains).
Add a ton of nature and actors procedurally located using your own assets choosing between the earth surface, underwater or both.
Use the modifiers to avoid locating assets in specific places.
Use the height range to avoid locating assets in different heights.
Optimize the generated nature by easily tweaking the cull distance of the generated assets.
Blueprint-friendly library to generate different shapes and use it with the UE4 ProceduralMeshComponent.
Support to create Static Mesh asset from generated terrain mesh.
Support to create heightmaps as png images from Plane terrains.
Code Modules:
FastNoiseLite (Runtime)
RuntimeMeshComponent v4.1.5 (Runtime)
ProceduralTerrainGenerator (Runtime)
ProceduralTerrainGeneratorEditor (Runtime)
Number of core Blueprints: 28
Number of C++ Classes: 3
Supported Development Platforms: All, except iOS, Mac, Android and Win32
Supported Target Build Platforms: All, except iOS, Mac, Android and Win32
Tested on: Windows 10/i7 6700K/GTX 1060/32GB DDR4 Ram
喧闹任其喧闹,自由我自为之
wangzhenmo  发表于 2022-6-9 19:35:46
煎饺jianjiao 实名
煎饺
3 小时
短杖 火元素
