定格动画教程(英文字幕) Skillshare – Frame by Frame Animation Using Photoshop......
151 1
发布于 2023-4-8 09:16:07
AE+C4D+PS定格动画教程(英文字幕) Skillshare – Frame by Frame Animation Using Photoshop After Effects Cinema 4D
讲解再C4D中制作简单的人物模型动画、给PS定格动画做参考,然后导出所有的定格到AE中进行后期合成处理
I will start by showing you some free resources that you can download and how to use Mixamo to animate your 3D characters.Then I will show you how to create your first animation in Cinema4D and use it as a reference to draw all the frames in Photoshop, using a screen or graphic tablet.After you export all the frames, we will move to After Effects to make our animation more trippy and do some final adjustments.In the end I will show you some alternative ways to create a frame by frame animation,without using Cinema4D.
首先,我将向您展示一些可以下载的免费资源,以及如何使用Mixamo为您的3D角色设置动画。然后,我将向您展示如何在Cinema4D中创建第一个动画,并将其用作在Photoshop中使用屏幕或图形平板绘制所有帧的参考。导出所有帧后,我们将移动到After Effects,以使动画更加逼真,并进行一些最终调整。最后,我将向您展示一些不使用Cinema4D创建逐帧动画的替代方法。
古今多少事,都付笑谈中
