AE复制遮罩到图层脚本 Aescripts CopyMask2Layer V2.2.002
214 0
发布于 2023-4-9 12:36:13
AE复制遮罩到图层脚本 Aescripts CopyMask2Layer V2.2.002当我们把遮罩从一个图层拷贝到另一个图层的时候,遮罩的位置往往会发生改变,这个脚本可以完美解决这个问题,即使这个图层是运动的或者遮罩有关键帧,CopyMask2Layer适用于任何2D图层When you copy a mask from one layer to another it often changes its position. With CopyMask2Layer you can copy masks while keeping them perfectly in place – even if the layers are moving and if the mask path is keyframed.CopyMask2Layer works with masks on any 2D layers.
Aescripts CopyMask2Layer 2 v2.2.002 (WIN, MAC):When you copy an image between layers the next and back, it will change its location. With CopyMask2Layer you can duplicate masks and keep their exact position - even when the layers are changing and the path of the mask is keyframed.CopyMask2Layer is able to work with masks on every 2D layer.New in Version 2Version 2 CopyMask2Layer is able to support the rotobezier mask.
古今多少事,都付笑谈中
