AE常用网格参考线生成脚本 Aescripts GuidesUp V2.2.3
173 0
发布于 2023-4-11 22:19:33
Free Download Aescripts GuidesUp! v2.2.3 (WIN, MAC)
Aescripts GuidesUp! v2.2.3 (WIN, MAC):Create magnetic 3D isometric Maps with just one click. Set up Golden Ratio Guides 16:9 guides and Hex Map…And more importantly, control anchors, items, and guides unlike ever before!Then, navigate to”View,” then select the “View” menu, then select “Show Rulers”, then select “Show Guides” (or Ctrl/Cmd +R, then Ctrl/Cmd +, and so on). .)… This is repeated several times per project, per comp every day, each month, or per year, every decade?By using “-GuidesUp!” You’ll be able to:
  • Create and utilize your own Isometric magnetic map with just one click!
  • Create a Hex map
  • Create a grid that is based on the Golden Ratio NEW: Shift + click to use the rule of thirds guide!
  • “Frame items” (set automatically guides for shapes, footage, etc.) on multiple layers
  • Install your “ALL, TOP, LEFT, RIGHT or BOTTOM ” Guides even on multiple layers
  • Guides to position on Anchor items Point
  • Toggle Snap (magnetism of the Rulers)
  • Toggle Show Guides
  • Download and save Guides in one click!
  • Include cinematic black banding (because this is cool)
  • Cache on disks and empty memory
可以一键生成各种常用的参考线,比如黄金分割线、16:9、蜂窝、制作等距视差三维效果等Create a magnetic 3D isometric Map in 1 click, set up Golden Ratio Guides, 16:9 Guides, Hex Map…And above all, manage items, anchors and guides like never before!
古今多少事,都付笑谈中
