AE物体弹跳小球动画脚本 Aescripts Easy Bounce Pro V1.0.001
127 1
发布于 2023-8-2 22:26:07
只需要给图层简单做需要弹跳的位置关键帧,点击脚本,即可自动加上模拟小球的弹跳动画效果
Create bouncing animations the easy way! Just roughly keyframe the motion path you’d like, and let Easy Bounce take care of the rest
Workflow
  • Step 1: Roughly keyframe the motion path you want. Make sure to add a keyframe at each point where the layer will bounce, and one at every peak. No need to worry about the timing, or the exact path from keyframe to keyframe.
  • Step 2: Click the Easy Bounce button. It will then calculate all the physics parameters needed to create a realistic bouncing movement along the path you’ve chosen, and change your animation accordingly.
Yes – it’s really that easy!
古今多少事,都付笑谈中
人性本孤独  发表于 2023-4-11 14:15:54
