参考线控制AE脚本 Aescripts GridGuide V1.1.006
125 1
发布于 2023-4-16 21:23:02
https://youtu.be/36ocg5bpJYk QQ截图20220611032012.png QQ截图20220611032028.png
在AE中生成各种方向间隔大小的参考线,方便制作排版动画Automatic layouts, snappable guides grids and modifiable shape layer guides – because motion design isn’t static.
Key Features
  • Auto Layout improves your designs – even for people with no design background. Just place your layers roughly where they should be, select them, and click the Auto Grid & Snap button. GridGuide applies fundamental design rules to improve the placement and size of your layers, determining the grid that best fits your content.
  • Modifiable Shape Layer Guides – because motion design isn't static. GridGuide's grids are based on shape layers, which means that you can move, rotate, scale, parent and keyframe them just as any other layer. Don't limit yourself to static designs – let your guides follow your motion.
  • Intuitive Alignment Tools – allows you to align, scale and stretch layers. Just click them several times to make a layer jump from one grid line to the next. Of course, the alignment tools also work on rotated grids.
  • Native, snappable After Effects guides – if you prefer guides that you can snap to interactively, you can convert your shape layer guides to native After Effects guides using the Convert Grids to Guides button. There are many ways to create grids in After Effects, but GridGuide is the only automated solution to create truly snappable guides!
  • Fully customizable grids including controls for gutter, margin, stroke color, stroke width, and more. What’s more, GridGuide supports both bounded and infinite grids, as well as grids that consist of horizontal or vertical lines only.
  • Single Lines and Crosshairs add even more flexibility to your design. Of course, the alignment tools work with those lines, too – even if there are many of them in the composition.
古今多少事,都付笑谈中
逆水寒  发表于 2022-6-10 21:43:46
