尊敬的 游客,如果您要查看本帖关注 或 回复可见内容请 关注或 回复后刷新页面查看!
制作延迟拖尾效果,可以用来制作MG动画,MG转场等,可以用于图形层,文字层,3D层,可控性十分强大,MG爱好者不要错过 Vigoro is a powerful and extremely customisable tool to create amazing offset animations that would take hours or days to set up traditionally. You can create a whole array of animations – from simple labels, to transitions, to full illustrations! Everything can be offset, tweaked, and keyframed – and with over 150 keyframeable options the possibilities are limitless!
Features- Offsets: You can offset time, scale, rotation and a whole host of other things to make really fluid, complex animations with as few as 2 keyframes!
- Colors: Colors of your layers can changed really simply by selecting the top and bottom colors, and letting Vigoro do the rest. However, if you want to get a little more in-depth, you can sample layers for your fill and stroke. Make complicated gradients, animate them, add more gradients or effects, and make it as detailed as you want!
- Cut Effects: Want to spice up your animation a little more? 5 different Cut Effects allow for a huge variety of looks, and each has a multitude of options to play with!
- Distribution: Easily distribute your layers! You can offset radially or linearly, and 3D distributions are fully supported.
- Speed Modifiers: The Speed Modifiers will let you use the velocity of existing keyframes to add additional transformations and movement to your animation without having to keyframe them!
- Cloner: Repetition gets a bad rap, but sometimes it can add a lot! Clone your shapes and offset the clones to create amazingly complex compositions.
- Text Layers: Use text layers and breathe a whole new life into your animations - use distributions and cuts, or wiggle the text around for some really cool effects.
- Convert Layers: Use precomps, videos, images or more in your Vigoro animations!
- 3D Layers: In Vigoro, each layer is set up ready for 3D use, and alongside the flexible compositions you can add cameras, lights or whatever else you might want!
- Custom Layer Controls: You can now individually adjust each layer, to allow for an ever greater breadth of possibilities. Want to make that layer go a bit off to the side? Or change the color? Or arrange layers into pictures? No problem! Just choose the layer you want, and make adjustments in the Effects panel.
UI- Dockable UI Panel: Choose your composition name, set options, and always have it ready to go when you need to create a new Vigoro Composition!
- Easy Default Settings: Set defaults for your Vigoro Compositions so your compositions will always be created as you want them.
- Flexible Compositions: Each composition is created with a 'stack' of Vigoro Layers, with layers to mark the start and end of the stack. Outside of those layers, you can do whatever you want! Add backgrounds, text layers, cameras, adjustment layers or whatever else you might want! It's a great way to speed up your workflow.
- Bake/Freeze Panel: Bake and freeze your compositions to speed up your project! Easily choose which aspects of your composition you want to freeze, lock layers to keep them safe, and bake away! The Bake/Freeze panel works outside of Vigoro as well, so you can use it wherever you need!
InstallationInstalling Vigoro couldn't be easier! Simply extract the ZIP file wherever suits you best, and then copy the Vigoro.jsxbin and the Vigoro folders to your Script UI panels. The locations of these should be as follows: - Windows: C:\Program Files\Adobe\Adobe After Effects CC\Support Files\Scripts\ScriptUI Panels\
- Mac: \Applications\Adobe After Effects CC\Scripts\ScriptUI Panels\
Once you've copied the files, just open After Effects and open the Vigoro.jsxbin window (it should be at the bottom of your Window Panel at the top). Now you're good to go! NOTE FOR CS6 & CC!Vigoro uses 'Pseudo Effects' to create the nice control panels included in Vigoro. Inside the ZIP file you've downloaded is a file called [PACK] Vigoro UI Installer.jsx - installing this will allow these panels to run without any errors. If you don't want to install them everything should work just fine, but you'll get some errors about 'Missing Effects' when you create a new Vigoro Composition. To install this pack, run AE and then go to File>Scripts>Run Script File... - Find [PACK] Vigoro UI Installer.jsx wherever you've extracted it, and run it. After it's installed you'll be prompted to restart AE. Upon reopening, everything should be working! If you're running CC2014 or later, you do not need to run the [PACK] installer!
