AE三维体积感生成插件 Aescripts Volume n’ Tricks V1.0.5
116 2
发布于 2023-8-4 21:03:46
只需要一个图层,就可以控制多个方形的三维挤出效果,模拟真实的三维体积效果Design from new perspectives and amaze yourself: Give beautiful volume to your layers without using 3D layers or cameras.
Aescripts Volume n’ Tricks v1.0.7 (WIN, MAC):Create new ways of thinking and be amazed: Add stunning volumes to your layers, without 3D cameras or layers.Volume n Tricks is a useful toolkit that is included in After Effects:
  • Produce 24 isometric projections (3*4 * RTL and LTR) + 8 Skewed (bias) projections.
  • Create an isometric grid that is scalable.
  • For shape and text layers, create an extrusion having a specific FX volume
  • Install the light and set its brightness angle
  • Create shadows (mimicked) shadows to control its properties
  • Apply a gradient, and then select various blend modes
  • You can fine-tune the gentle falloff.
  • Extrusion can be used for text and shape layers as well as Vector files (Illustrator .ai) as well as .eps
  • The footage could be projected across all directions.
  • Plus there's More...
Everything is 2D with only a single flat layer. Keys can be added to virtually all properties, including Extrusion.Vn'T won't duplicate layers aside from backups of layers of text or Illustrator (.eps, .ai): It works on a single layer .)Design with new perspectives and surprise yourself:Transform your layers into 2.5D without cameras or 3D layers!New changes:
  • Fade issue resolved
  • .zip archive issue
  • Moving objects made easier!
  • the progress bar and debug
  • 1.7 Compatible with expressions embedded (wiggle, transform, position, scale, etc.), Fresh UI, Progress Bar, and More Control!
    Fixed: an alert message.
古今多少事,都付笑谈中
章得帅  发表于 2022-7-5 15:58:18
666666666666666666666
zyh1230123  发表于 2023-4-15 14:18:46
看看。。。
