[材质贴图] blender 怎么将黑白图像转换成法线贴图混合器?
查看:1162 |回复:2 | 2022-6-16 23:40:41
我有这么一张图:
image.png 我想把它映射成一个normal的贴图,黑色是较低的部分,白色的部分是凸起的。我尝试了这个节点图: image.png
但是它显然不起作用。如何将这样的黑白图像转换成凹凸贴图?
解决方法:
Bump from Height ...Displacement > type Bump from Height ...
Displacement > type Displacement as real geometry in render. Commonly called Micro-displacement ...For that effect you have to under Subdivision Surface modifier enable Adaptive Subdivision than you can in material setup switch Settings > Surface > Displacement type
Normal Map
If you are really looking for Height map to Normal map convert, check this Bake Normal ...
2022-6-16 23:40:41
2个回答,把该问题分享到群,邀请大神一起回答。
2023-2-13 11:24:55   回复
这软件功能好像很强大,就是太难上手习惯了
2023-2-14 11:38:30   回复
