捕捉对象、顶点、曲线点 QuickSnap
90 0
发布于 2023-6-1 12:03:50
https://pan.baidu.com/s/1a3TScrBKnR54K8NVg7QE0A?pwd=moku
作者
Julien Heijmans
QuickSnap是一个免费的搅拌器插件,允许通过选择源和目标点来快速将对象/顶点/点捕捉到对象原点/顶点/点,类似于Maya / 3Dsmax中顶点捕捉的工作方式。
特征:
  • 从/到以下位置对齐:
    • 场景光标
    • 对象源
    • 顶点和曲线点
    • 边缘中点
    • 面部中心
  • 饼图菜单允许您更改捕捉自/点的点类型。使用与用于启动工具以显示菜单的热键相同的热键。
  • 启用“在编辑模式下使用顶点自动合并”选项后,顶点将在捕捉后自动与同一位置的顶点合并。它可以在插件首选项中完全禁用。
  • 使用 (Shift+)X,Y,Z 热键在单个轴或平面上约束平移
  • 自动显示要捕捉到的网格的线框,并在鼠标正下方显示对象的线框(可关闭)
  • 捕捉到可见和不可见的点(优先选择离相机较近的点)
  • 突出显示目标顶点边缘,以及潜在的目标边缘中点和目标面中心,以获得更好的可读性
  • The addon includes the Blender Addon Updater that allows to update the addon easily from within Blender. You will also be notified if a new version has been released. You can enable/disable that behaviour in the addon preferences.
Add-On hotkey and settings:
  • By default, enable the tool by using Ctrl+Shift+V (For Vertex). Watch out if you have multiple keyboards to your windows settings, Ctrl+Shift will cycle the active keyboard.
  • Use the same hotkey to display the pie menu
  • Change the tool hotkey from the Add-On settings window
  • Discover the other hotkeys in the add-on settings, and tweak your own preferences
Use the tool:
  • Select the object or the vertices/edges/faces/curve points you want to move
  • Enable the tool using the hotkey (Ctrl+Shift+V by default)
  • With the tool enabled use the same hotkey (Ctrl+Shift+V by default) to open the pie menu and chose what you snap from*to (Vertices and curve points / edge midpoints / face centers)
  • Finally, to snap you have two options:
    • Click and drag:
      • Move the mouse over the point you want to snap FROM
      • Click an hold the right mouse button, mouve the mouse over the point you want to snap TO
      • Release the mouse
    • Two-Clicks:
      • Click on the point you want to snap FROM
      • Click on the point you want to snap TO
  • If you want to cancel the operation:
  • Press Right Mouse Button or ESC key to cancel the translation
Important notes:
This tool is not made to use on very high poly objects, and performance might get poor when many really heavy objects are under the mouse. Look at the documentation page to find more information about this.
Update the Add-On:
  • In the Add-on preferences, scroll down, click on "Check now for QuickSnap update"
  • If the same button now says: "Update now to (x,y,z)" it means that a new version exists. Click that button to update, then restart Blender.
  • Here is a video showing how ot update the add-on from within blender: (You need to click on the play icon in the top right corner)
Bug Report:
  • If you have an issue, first check that you have the last version of the addon (Instructions above)
  • 如果最新版本的插件问题仍然存在:
    • 请在此处创建一个问题,我会尝试尽快解决问题:https://github.com/JulienHeijmans/quicksnap/issues
    • 不要忘记解释当问题发生时,你正在做什么以及你的场景中发生了什么。如果可以共享场景,也可以共享。
建议/功能要求:
如果您有一些功能想法或建议,请随时在这里给我发消息,或在此处发布:https://github.com/JulienHeijmans/quicksnap/discussions/categories/ideas
由于我没有从这个插件中赚钱,我不能保证我会有时间实现它,但我一定会考虑它。
已知问题/限制:
  • 目标突出显示在启用“忽略修饰符”的情况下不起作用。我计划研究忽略修饰符的新方法,这些修饰符可能允许在这种情况下突出显示。
  • 在编辑模式下,工具将始终使用网格的原始点(不带修改器)
参与人数 3元素币 +19 活跃度 +11 展开 理由
swatlyh + 6 + 4 666
drogscool + 4 + 4 如此优秀,不顶对比起楼主
qaz7639327 + 9 + 3 楼主有心了
先学了在说
