Tissue v0.3.53 for Blender 3.2.1
91 1
发布于 2023-6-17 19:28:07
链接:https://pan.baidu.com/s/1WQi4ZkgZxvXaBr7wZS9Plw?pwd=2bbs
提取码:2bbs
Center option, that combines the behaviour of Fan Tessellation with the Frame Tessellation. It allows merging the components in the centre of the face together with an integrated opening control using the Vertex Groups. In addition, when working with Triangles, it uses the Incenter instead of the default average point. This produces a more uniform thickness for triangular faces.Vertex Groups for controlling the thickness of the frames.Face Weight for a uniform frame thickness for the individual faces. As opposed to the default Vertex weight.Frame Boundary Thickness, for controlling independently the thickness of the boundaries.
“中心”选项,将“扇形细分”的行为与“帧细分”相结合。它允许使用“顶点组”将面中心的组件与集成的打开控件合并在一起。此外,在使用三角形时,它使用“增量”而不是默认的平均点。这将为三角形面生成更均匀的厚度。用于控制帧厚度的顶点组。单个面的统一框架厚度的面权重。与默认“顶点”权重相反。框架边界厚度,用于独立控制边界的厚度。
Teny  发表于 2022-11-6 20:02:56
谢谢楼主分享!!!
