Unity3D资源 [功能/工具] ProPixelizer 1.71
140
7
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 辅助建模 动画|特效 2D资源|工具 后处理 其他扩展
价格:200元素币(或20余额) 百度网盘 销售总额:800元素币 购买人数:4
尊敬的游客 ,本内容需要支付 200元素币十分之一的[余额] 来购买.
需要URP
Features:
特征:
Per-object pixelization: mix scenes of pixelated and unpixelated objects. Individual objects may be pixelated in 'macropixels' of up to 5x5 screen pixels in size.
每对象像素化:混合像素化和非像素化对象的场景。单个对象可以像素化为最大5x5屏幕像素的“宏像素”。
Per-object outlines: Outlines can be block color or tinted, and controlled separately for each object. Supports both silhouette and normal-based outlines.
每对象轮廓:轮廓可以是块颜色或着色的,并为每个对象单独控制。支持轮廓和基于法线的轮廓。
No pixel creep when using orthographic projection.
使用正交投影时没有像素移动。
Lighting and shadows: including shadows cast between pixelated objects and unpixelated objects.
照明和阴影:包括在像素化对象和非像素化对象之间投射的阴影。
Compatible with ShaderGraph - just use the provided nodes in your materials (example ShaderGraph asset included).
与ShaderGraph兼容-只需使用材质中提供的节点(包括ShaderGraph资源示例)。
Per-object color grading and dither patterns - achieve a retro feel by using reduced color palettes. A selection of dither patterns (or no dither) are supported. Editor tools to create dither patterns and palettes.
每对象颜色分级和抖动模式-通过使用减少的调色板实现复古感。支持选择抖动模式(或无抖动)。用于创建抖动图案和调色板的编辑器工具。
Compatible with post processing effects, such as depth of field, bloom, vignette.
与后期处理效果兼容,如景深、开花、渐晕。
WebGL support - see the demo on itch.io..
WebGL支持-请参见itch.io上的演示。。
Unlike other pixelization effects, ProPixelizer keeps the screen rendered at full resolution. This allows pixelated objects to move at screen resolution, without creep. It also allows seamless blending of pixelated and unpixelated objects, and use of high resolution post processing such as bloom and/or depth-of-field.
与其他像素化效果不同,ProPixelizer保持屏幕以全分辨率渲染。这允许像素化对象以屏幕分辨率移动,而不会发生移动。它还允许像素化和非像素化对象的无缝混合,以及使用高分辨率后期处理,如开花和/或景深。
Works well with low-poly 3D models.
适用于低多边形3D模型。
Requirements:
要求:
For Universal Render Pipeline only.
仅适用于通用渲染管道。
The latest version of ProPixelizer has been tested with Unity 2022.1.8f1 & URP 13.1.8, Unity 2021.3.6f1 & URP 12.1.7, and with Unity 2020.3.36f1 & URP 10.9.0.
最新版本的ProPixelizer已通过Unity 2022.1.8f1和URP 13.1.8、Unity 2021.3.6f1和URP 12.1.7以及Unity 2020.3.36f1和URP10.9.0测试。
Performs a postprocessing effect to pixelate objects, which is implemented through an included Render Feature.
执行后处理效果以像素化对象,这是通过包含的渲染功能实现的。
Pixelated objects must be opaque, although alpha cutout is supported, and dithered fading.
像素化对象必须是不透明的,尽管支持alpha剪切和抖动衰减。
The post process samples the screen buffer in a 5x5 pattern. Performance may be slow on low end hardware.
后处理以5x5模式对屏幕缓冲区进行采样。低端硬件上的性能可能较慢。
Please note - models, textures and other assets shown in the screenshots are not included. This package only contains the pixelization shaders and materials.
请注意,屏幕截图中显示的模型、纹理和其他资产不包括在内。此包仅包含像素化着色器和材质。
参与人数 3 元素币 +19 活跃度 +7
zwxzxl  发表于 2023-1-4 22:15:43
b877168688  发表于 2023-1-5 05:34:51
小二有点二  发表于 2023-4-27 16:22:30
路过留个脚印
宸宇  发表于 2023-5-16 14:50:57
好资源,感谢分享~!
狂奔de蜗牛  发表于 2023-5-25 09:50:04
阿浩1989  发表于 2023-6-8 08:53:00
88888888
370688535 实名
鼓励师
2735 小时
长剑 赤铁剑 元素铜币 元素银币 元素金币 短杖 长枪 龙枪 学徒法袍 无色原始矿 绿母翠晶矿 彗星钛晶矿 蓝色药水 紫色药水 赤色药水 粒粒皆辛苦 火元素 裁决 【绝】千人纪念徽章 短剑
