Blender-摄影棚三维灯光渲染 Quick Studio V1.0 +预设库
11180 4
发布于 2023-8-7 18:35:33
价格:60元素币(或6余额) 百度网盘 销售总额:60元素币 购买人数:1
尊敬的游客 ,本内容需要支付 60元素币十分之一的[余额] 来购买.
Quick Studio 的目的是让您立即为渲染和动画创建高质量的场景。为此,它不仅包括工具,还包括一整套可编辑资产。它分为三个主要部分:背景、灯光和世界。所有这些都包含在同一个面板中。包含的所有资产都设计为可定制、易于使用、渲染速度快且外观精美。The purpose of Quick Studio is to allow you to create high quality scenes for your renderings and animations in no time. To achieve this, it not only includes the tools but also a full set of editable assets. It is divided into 3 main sections: background, lighting and world. All of them contained in the same panel.安装方法:1.打开软件,顶部菜单点击 编辑(Edit) → 首选项(Preference) → 插件(AAdd-ons) → 安装(Install) ,在弹出的窗口里选择插件zip文件安装2.重启Blender,在 文件 → 用户设置 → 插件 里即可看到所安装的插件The add-on currently includes 16 editable backgrounds.Each background has its own set of parameters so that you can create unique custom scenes.It also includes 16 materials with 4K textures to apply to these backgrounds.And all of these can be edited with a few key parameters to increase customization.All the textures in Quick Studio come from ambientCG.com, licensed under CC0 1.0 Universal.
LightingQuick Studio improves light management in Blender and adds a new type of spot, point and area lights with new features:
  • Automatically create lights targeting an object.
  • Make the lights visible in the viewport and in render.
  • Spread parameter added in 2.8 and 2.9 versions before 2.93 (Cycles only).
Visibility options of the lights make it a lot easier to edit the lighting in the scene, providing a much cleaner view.All the lights will be listed in the panel with different UI options to suit your needs. Also, lights can be selected directly from this panel.Plus, the add-on includes 16 lighting presets to quickly add to the scene.
WorldQuick Studio allows you to edit separately the world settings for lighting, camera (the world seen by the camera in the background) and reflections. As always, each of them having the key parameters to easily customize the world.
But this is not all! There are more features included in the add-on: presets saving/loading, HDRI rendering tools and compositor tools.
PresetsSave and load the scenes you create with Quick Studio including the background, lights and world with all their parameters in just one click.
Render HDRIQuickly set up the scene to render it and save and HDRI image.
Compositor
Add the Studio Compositor node group to post-process your renderings with a set of key parameters. With just the mist pass you will also be able to add fog and DOF effects. Also, in the compositor side panel you will have the option to save and load the node settings.
Extra StuffThe .blend files included contain a lot of node groups, materials and models that you can use, inside or outside the Quick Studio add-on.For instance, the digital background uses a whole set of node groups to procedurally create patterns and graphics. Feel free to use them as you like! maxresdefault.jpg maxresdefault.png
参与人数 1元素币 +1 活跃度 +1 展开 理由
悠扬的G调... + 1 + 1 这就离谱
造风者~
wangzhenmo  发表于 2023-2-7 18:24:44
Teny  发表于 2023-2-7 19:34:03
谢谢楼主分享!!!
chenpan85  发表于 2023-3-19 17:21:22
zgp230  发表于 2023-4-25 15:46:25
带你赚币带你飞,元素里面有正妹。
