This post provides a cracked version of Substance 3D Designer V12.4.1 WinMac software, which allows for three-dimensional texture material creation. The installation steps involve running Setup.exe and then copying the Adobe Substance 3D Designer.exe file to the installation directory, which is by default at C:\Program Files\Adobe\Adobe Substance 3D Designer. If you want to change the installation location, you can modify the driver.xml file in the products folder with Notepad. One of the new features included in this software update is the ability to enter formulas directly into parameter fields, making it easier to input specific parameter values without the need for a calculator. Another feature is the addition of quick access buttons in the 3D view toolbar for easy access to all available display options. A new button has also been added for generating random seeds for chart variations. Additionally, users can now lock the output size width and height and quickly toggle between image input conversion to color or grayscale. Other updates include an automatic selection of corresponding pins in the displayed gradient editor when editing a pin from the attribute panel and a new option in the node context menu for selecting all downstream nodes connected directly or indirectly to the selected node output. These updates can improve workflow efficiency and make it easier to manipulate various aspects of the software.
