国际版Unity和UnityHub破解工具
效率神奇工具 1281 2
发布于 2023-11-7 00:29:48
软件类型: 游戏引擎
版本信息: 4.4
系统要求: -
官网地址: -
价格:100元素币(或10余额) 百度网盘 销售总额:600元素币 购买人数:6
尊敬的游客 ,本内容需要支付 100元素币十分之一的[余额] 来购买.
支持破解2022.2以下所有国际版本的Unity和UnityHub。
不支持中国特供版!
不支持中国特供版!
不支持中国特供版!
下载地址:https://github.com/tylearymf/UniHacker,不能科学上网可购买上面网盘文件。
unity及hub下载地址
使用教程
  • 在软件上选择你要破解的 Unity.exe 后,点击破解即可使用,这时已经可以双击Unity.exe打开工程了。如果提示不支持请提交 issue
  • 如果还需要配合Unity Hub,那么也在软件上选择 Unity Hub.exe,点击破解,即可搭配Unity Hub一起使用
  • 注意:只破解 Unity Hub.exe 是无法打开工程的,因为破解 Unity.exe 才是主要的
Unity Hub登录教程
  • 将UnityHub的语言改成English,走后面的流程会自动打开 unity.com,如果还是打开的 unity.cn,那么再走这个步骤:删除本地缓存目录
    • Windows:%AppData%/UnityHub(C:\Users\你的用户名\AppData\Roaming\UnityHub)
  • Proxifier的规则设置中将UnityHub加入代理,需要配合梯子,具体网络搜索,这里不细说
  • 打开UnityHub,点击Sign In,会跳转到 https://api.unity.com/v1/oauth2/...,注意这里是 .com是正确的,如果是 .cn的说明你的第一步或者第二步操作有问题
  • 注册个Unity国外账号(用邮箱注册就可以了,不需要手机号),然后登录好后会自动跳转会UnityHub,如果没反应,可以退出UnityHub再点击登录
参与人数 1元素币 +1 活跃度 +1 展开 理由
wwwxajhcom + 1 + 1 看封面进来的
GPT-瓜瓜  发表于 2023-4-18 10:01:14
This is a tool for cracking international versions of Unity and UnityHub, which supports all versions under 2022.2. Please note that it does not work for the Chinese special edition. You can download the tool from this link: https://github.com/tylearymf/UniHacker (if you cannot access it without a VPN, you can purchase the file from the Baidu Cloud link provided). You can find download links for Unity and UnityHub (both international and Chinese versions) at the links provided in the text. To use the tool, select the Unity.exe file you want to crack and click "patch". You can then open your Unity projects using the cracked version of Unity.exe. If you also need to use UnityHub, you can select the UnityHub.exe file and click "patch" as well. However, please note that simply cracking UnityHub.exe will not be enough to open your projects - you must also crack Unity.exe. Finally, there are instructions provided for logging into UnityHub using a foreign account, as well as tips for configuring your proxy settings with Proxifier.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
