element3ds.com
地编-CG场景 [引擎地编] The unexpected desk
33104
[翻译] : 我又制作了一次渲染,这次只是受到了现实生活中物体的启发。场景其实并不存在,所以我没有参考图片可以展示。这次我更多地尝试了构图、照明和叙事,以及在我的住所内创建一个独特的HDR贴图。为了减少渲染时间,我决定只渲染缩放动画的几个关键帧,并将结果拼接成一个大的超渲染。在新的场景中,我聚焦到这个新创建的超渲染上。我在帖子底部添加了一个场景概览。
所有内容都是在Blender中使用Cycles渲染的。大部分材质都采用了某种程序化方法,Megascans和Poliigon粗糙度贴图都非常有用。一些色彩校正和对间接照明、透射等渲染通道的调整是在Photoshop中完成的。
I made yet another render, this time merely inspired by real life counterparts. The scene does not actually exist, therefore I dont have any reference images to show. This time I experimented more with composition, lighting and storytelling aswell as the creation of a unique HDRI map inside my residence.To cut down on render time, I decided to only render a couple of frames of the zoom animation and stitched the resulting renders into a large super-render. In a new scene I zoomed into the newly created super-render. I added a scene overview at the bottom of this post.Everything was rendered within Blender using Cycles. Most materials are procedural to some degree, both Megascans and Poliigon roughness maps came in handy. Some color grading and adjustment of the render passes such as indirect lighting and transmission was done in Photoshop.
参与人数 1 元素币 +4 活跃度 +5
Artstation:https://www.artstation.com/roartal/albums/all
Markus_K 实名
3D艺术家
