element3ds.com
地编-CG场景 [CG场景] Jungle Rock Face Substance Designer
33168
[翻译] : 一个完全程序化的丛林岩石表面Substance材质。所有内容都是在 Substance Designer 中从头创建的。我开始这个 Substance 是为了探索是否能在不引入外部高度数据的情况下制作分支藤蔓。事实证明,通过一系列贴图采样器连接到后续节点的掩码是可行的。这个过程花费了一些时间,但非常有趣,希望你会喜欢!编辑:根据要求,我添加了一个只显示基础岩石层的版本。(感谢Bobby Rice的建议)
A fully procedural jungle rock face Substance material.Everything was made entirely in Substance Designer.I started this substance to see if making branching vines was possible without resorting to bringing in height data from elsewhere. It turns out it is possible using a sequence of tile samplers that feed into the mask of the subsequent node.This one took a while and was really fun to work on, hope you enjoy!EDIT I added a version showing only the base rock layer as requested. (Thanks to Bobby Rice for that idea)
参与人数 1 元素币 +8 活跃度 +1
Artstation:https://www.artstation.com/christopherhodgson
Chris_Hodgson 实名
资深环境美术师
