element3ds.com
原创SD-材质-渲染 Substance Designer 6 Beta Work
34624
[翻译] : 感谢Allegorithmic,我有幸在Substance Designer 6发布前试用了一些功能。在这个作品中,我充分利用了新加入的曲线节点,它可能是SD6里我最喜欢的特性之一。使用起来更加直观,它几乎取代了我工作流程中的三个其他节点!这个作品全部是立方体上的高度图。100% Substance Designer。在Marmoset Toolbag中渲染,灵感来自柬埔寨的巴戎雕像。
Thanks to Allegorithmic, I was one of several artists chosen to test out the Substance Designer 6 beta before release. For this piece I really put the new curve node to use and Its probably my most favorite new feature in SD6. It is just so much more intuitive to use. It has literally replaced 3 other nodes in my workflow! This is all heightmap on a cube. 100 Substance Designer. Rendered in Marmoset Toolbag  Inspired by the Bayon Statues in Cambodia
参与人数 1 元素币 +4 活跃度 +2
Artstation:https://www.artstation.com/donarceta
Don_Arceta 实名
艺术总监
