Midjourney v5.2,超强缩小功能上线及审美优化
2007 6
发布于 2023-6-28 18:48:14
一杯梵高的星夜送给大家
按官方说明文件,v5.2主要更新了四项功能,以下就让我们来看看新的版本有什么不同吧。
一、新的审美系统:
1、更好的美感与更清晰的图像。
2、增加文字的理解能力与逻辑连贯性。
3、增加图片多样性:每次跑的图较为多变。
4、stylize指令修正,效果增强。
* --stylize 范围为 0 到 1000,默认值为 100。
*复习一下 stylize值愈大,图片愈放飞自我,跟输入的prompt差距愈大。
我们直接用案例来看看 v5.1 与 v5.2 的差别:
v5.1
v
5
.2
model with platinum highlights, in the style of beauty use of color and color, nostalgia, close - up shots, hyper - realistic, saturated color scheme, beauty, emotive faces
v5.1
v5.2
celebrity with layered fringe, in the style of style use of lighting and lighting, space age, close - up shots, hyper - realistic, saturated color scheme, style, emotive faces
效果变化好像也没有很大,大家自行感觉多测试一下吧。
animal --ar 16:9 --s 999 --v5.2
ulzzang girl --s 999 --v5.2
Muscular man --s 999 --v5.2
二、新的高变化模式 "High Variation Mode" :
按下V的变化,会比之前的版本更大。下图是按了V3后的变化。
之前都是微调,这版确实比之前大了不少。若想变回之前的模式,可以在setting里改为 "Low Variation Mode" 设定。
三、新的缩短指令 "/shorten"
可以用这个指令来分析关键词并获得输入的关键词是否有效的建议。
我们来测一下这图的关键词有多少废词:
Photos of future cities taken from afar, Imagine a Ultra Wide Angle and Long Range bustling city of the future that is both sleek and sustainable. The city should feature towering skyscrapers that are powered by renewable energy sources, like solar and wind power. The streets should be lined with trees and green spaces to provide a break from the concrete jungle and improve air quality. Consider designing transportation systems that are efficient and environmentally friendly, such as electric or self-driving cars, or even flying vehicles. The city should also feature cutting-edge technology, like augmented reality interfaces or holographic displays, that enhance the daily lives of its citizens. Finally, consider how the city's architecture can reflect its forward-thinking approach, with unique and innovative buildings that stand out as landmarks of the future --ar 16:9
输入 /shorten 加上上面一大串关键词后会出现下图:
可以看到有很多无效词被删掉了,下面还会再给出5条建议选项,如此也应验了我们之前说的关键词不是愈多愈好。
也能拿之前一些自己比较喜欢的图片关键词,用这功能再测一下自我优化,可能会有意想不到的收获哦。
四、新的缩小功能:
终于讲到这个最重要的更新功能,每张U后放大的图片,下方都会出现新选项,下面我们就用这个冷酷的女王来做个案例吧。
先选一张自己喜欢的图,放大一下,这边我选了U2。
这时会发现下面的选项跟之前版本不一样了,说明如下:
1、Vary (Strong):较强的变化
就是之前的V,但这个表现会比之前变化更大
2、Vary (Subtle):微小的变化
也是之前的V,但只对画面做细微调整。
说实话,这次的 V 改得比旧版好用1万倍不只,不是变化大小的问题,而是之前只要一按 V 90%以上几乎都是歪嘴、斜眼、手骨折、脚抽筋,这版几乎都很完美了,99分!
3、Zoom Out 2x:缩小2倍 与 Zoom Out 1.5x:缩小1.5倍
上面这两个功能相同,缩小倍数不同而已,一次虽然只能缩小2倍,但可以一直缩小下去,感觉可以无限缩小。
Zoom Out 2x
再Zoom Out 2x
再再Zoom Out 2x
可以看到,MJ会按原图进行缩小,并按输入的关键词进行整个画面的构图。有时常常主题会画得太大,这样可以进行一次缩小调整也不错。
想再缩小的可以继续自己测试一直缩小。
4、Custom Zoom:自定义缩小
可以调整长宽比跟缩小倍数,这个功能很方便,可以把1:1的画面调整为直的(2:3)或横的(3:2)都行。缩小倍数为1x~2x之间。
--ar 16:9 --zoom 1
只在原图上进行横向16:9的扩展,不进行缩小。
5、Make Square:改为正方型
这按钮不论原图比例多少,直接将图片改为1:1正方型
新版本我个人最喜欢的地方就是按V后嘴不歪眼不斜了,再来就是自定义的变长变宽,有时画到一张很喜欢的图,但想改为横版或直版的,每次都要拿到 DALL-E2 去调整,就让人很无力。现在MJ自己就可以搞定了,很不错。大家快快去测试吧~
参与人数 3元素币 +25 活跃度 +11 展开 理由
龙哥Longer... + 9 + 3 卷起来
amenjuzi + 10 + 3 楼主辛苦了
makezero + 6 + 5 留个爪印,来日再品
yangfeng  发表于 2023-6-29 14:08:22
强啊 我好喜欢这个
虞不姬  发表于 2023-6-30 17:18:51
质感很不错,牛
宸宇  发表于 2023-7-2 09:21:33
感谢楼主的分享
shanggeyun  发表于 2023-7-8 08:47:40
齐济沧海  发表于 2023-8-29 14:32:01
6666
