element3ds.com
SD-材质作品 Midjourney AI - Plastered Stone Wall
35297
[翻译] : 又开始了!这次我决定不在Substance Sampler里花太多时间修改我不喜欢的区域,而是直接在Designer中制作一个更大的自定义贴图。我重新构建了很多高度信息,并增加了许多微表面细节到法线贴图上。我还调整了许多颜色并改变了散射效果。为了填补岩石之间的缝隙,我使用了Megascans提供的材质,对其进行了一些加工,并利用高度融合让它们更好地衔接在一起。
Here we go again!This time I decided to avoid doing too much work in Substance Sampler fixing areas I dont like and instead made a larger custom pass in Designer. I rebuild a lot of the Height, as well as added a lot of micro surface details in the Normal on top. I also redid a lot of the colors and changed the scattering.To fill the gaps between the rocks I used a material from Megascans, overworked it and used some Height Blending to get the materials fit well into each other.
参与人数 1 元素币 +3 活跃度 +5
Artstation:https://www.artstation.com/kaikizzle
Kai_Kizzle 实名
材料与环境艺术家
