原创特效作品 [其他] (2022) Anime Look Stylized Explosions
52797
2
[翻译] : 我现在没太多时间,所以会一点点分段发布。感谢理解。-----------------------------尽管它不如2D动画出色,但3D的优势在于可以从各个方向观看,并且便于添加随机性和互动性。我认为在VR中它看起来会是3D的,因为它基于3D网格构建。除了透明的风效,没有使用纹理。所有内容(除了风效)都使用了遮罩混合模式,是不透明的。[视频=
NOTEI cant make much time now, so Ill post small breakdowns little by little. Thanks for the understanding.-------------------------------------------------------------Although it is still not as good as 2D animation, the advantage of 3D is that it can be viewed from all directions, also making it easy to add randomness and interaction.I think it will look 3D in VR because it is constructed with a 3D mesh.No textures are used except for translucent wind FX.Also, all but this wind FX are opaque with Masked Blend.
参与人数 8 元素币 +40 活跃度 +23
A站:https://www.artstation.com/ikewata1106
赤雨落  发表于 2023-7-17 16:04:34
元素界王神  发表于 2023-9-1 19:20:52
帅炸了!
Wataru_Ikeda 实名
Senior VFX Technical Artist @
