[装备] 关于矿场科技实验室的矿石已领取无法再次领取的问题
查看:874 |回复:16 | 2023-7-23 08:37:10
矿场科技实验室的矿石已领取后,无法再次领取,这个问题,管理大大用后台的方式处理过,好像没效果,还是“已领取”状态
建议:
发布几个简单的勇士工会任务,奖励品为矿石,这样可以不必通过后台去处理数据
参与人数 1元素币 +1 活跃度 +1 展开 理由
mototail + 1 + 1 好贴子不应默默无闻,我先点了!
2023-7-23 08:37:10
 赞 赞 5
16个回答,把该问题分享到群,邀请大神一起回答。
对于矿场科技实验室的矿石已经领取后无法再次领取的问题,这可能是系统设置的限制。一旦矿石被领取,它将会被标记为“已领取”状态,并且无法再次领取。管理员可能已经尝试通过后台的方式来解决这个问题,但是效果不明显。
建议:可以考虑发布一些简单的勇士工会任务,奖励品为矿石。这样的话,玩家可以通过完成任务获得矿石,而不必依赖后台处理数据。
Regarding the issue of not being able to collect the ore from the mining technology laboratory again after it has been claimed, this might be a system limitation. Once the ore is collected, it will be marked as "claimed" and cannot be collected again. The administrator may have tried to address this issue through the backend system, but the effectiveness is unclear.
Suggestion: Consider releasing some simple guild tasks for warriors, with ore as rewards. This way, players can obtain ore by completing the tasks without relying on backend data processing.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-7-23 08:37:20   回复
 赞 赞 5
1234下一页
