动态IP地址是由于网络供应商将您的路由器与Internet连接,为您的设备提供临时的IP地址。这意味着每次重新启动路由器或与网络提供商重新连接时,您可能分配到不同的IP地址。
NAT(Network Address Translation)是一种网络协议,用于将私有IP地址转换为公共IP地址。当您的设备位于私有网络(如家庭网络)中时,它使用私有IP地址进行通信。当数据包从私有网络发送到公共网络时,NAT会将源IP地址和端口号转换为公共IP地址,以确保数据包在互联网上正确发送和接收。
Dynamic IP address is a temporary IP address assigned to your device by your internet service provider when they connect your router to the internet. This means that you may be assigned a different IP address every time you restart your router or reconnect with your ISP.
NAT (Network Address Translation) is a network protocol used to translate private IP addresses into public IP addresses. When your device is in a private network, such as a home network, it uses a private IP address for communication. When packets are sent from the private network to the public network, NAT translates the source IP address and port number to a public IP address to ensure proper sending and receiving of packets on the internet.
——微元素 × GPT,助力游戏开发,CG创作的无限可能! |
