自动生成各种建筑风格模型,Blender插件Auto-Building 1.1
323 18
发布于 2024-5-1 21:46:02
价格:220元素币(或22余额) 百度网盘 销售总额:0元素币 购买人数:0
尊敬的游客 ,本内容需要支付 220元素币十分之一的[余额] 来购买.
通过此附加组件,您可以输入各种建筑元素,例如门、窗、面板等,这些元素将按程序分布在简单的网格上,从而形成复杂而详细的建筑。With this add-on, you can input various building elements such as doors, windows, panels, and more, which will be procedurally distributed across a simple mesh, resulting in a complex and detailed building.It comes with a custom interface to make the creating process easy for you. You don't need to know geometry node to use it! Simply drag and drop the collections of object you want to use and change the settings to get the result you want. The beauty of this add-on lies in the balance it offers between automation and manual control. While it streamlines the building creation process, it also allows you to retain some handmade modeling control. This way, you can fine-tune the look and achieve the exact aesthetic you desire. :)The main idea of the tool workflow is that you will assign special materials to the faces you want to see turned into objects. And if this is object has a mesh with a boolean material applied to it, it will even create a hole in your facade. No more flat windows because you're lazy to add a hole in your facade! The add-on automatically place then for you.
参与人数 7元素币 +41 活跃度 +17 展开 理由
拷给你 + 3 + 2 这个要顶一下了
佛小念 + 10 + 2 楼主辛苦了
lzf123qw + 4 + 5 看好楼主
aiko33 + 6 + 2 楼主终于出手了
guangjingw... + 3 + 2 腰间盘都没有你突出
hogenxie + 8 + 2 往死里卷啊这是
浮世绘 + 7 + 2 前排围观
仰空越梦  发表于 2023-8-23 11:05:50
gmcc020322  发表于 2023-8-23 13:25:10
辣辣1912  发表于 2023-8-23 13:57:36
jaegerleecoutre  发表于 2023-8-24 07:13:43
狂奔de蜗牛  发表于 2023-8-24 09:55:32
狂奔de蜗牛  发表于 2023-8-25 10:01:56
晚安少年  发表于 2023-8-25 17:21:05
现在vcn现场直播  发表于 2023-8-27 00:17:38
失落  发表于 2023-8-28 10:58:38
每天一早上元素,挖矿撩妹两不误
筱夜喵喵喵  发表于 2023-10-25 10:54:40
这个好用吗,有没有老哥解答一下
lalalak  发表于 2023-12-2 14:17:56
17#
狂奔de蜗牛  发表于 2024-1-25 09:44:38
18#
suty2004  发表于 2024-3-29 16:11:07
19#
666
