[1] CLONER MODE[1] 克隆模式
Grid Mod - Grid Mode same as Cinema 4D classic Grid Mode网格模式- 网格模式与 Cinema 4D 经典网格模式相同
Linear Mode - same as Cinema 4D classic Linear Mode线性模式 - 与 Cinema 4D 经典线性模式相同
Object Mode - Can use the geometric normal space to define the rotation axis of the instance.对象模式- 可以使用几何法线空间来定义实例的旋转轴。
Definition Instance:
Pick to instances or keep original.
Collection to instances.
Separate Collection Switch.
定义实例:
选择实例或保持原始。
集合到实例。
单独的收集开关。
[2] EFFECTOR TYPEEffector is to control the transform of instances
Random Effector - The random effector affects the values
[2] 效应器类型Effector是控制实例的变换
随机效应器- 随机效应器影响值
Noise Tex Effector - The noise effector affects the values in space through a noise node.
Noise Tex Effector - 噪声效应器通过噪声节点影响空间中的值。
Image Tex Effctor - Effects the value in space.
Image Tex Effctor - 影响空间中的值。
Image Tex in UVMap Space
UVMap 空间中的图像 Tex
Step Effector - The step of change of the value is based on the Index order of the instance.Press TAB after selecting the node to get more control.
