UVPackmaster Pro高效UV贴图Blender插件V3.1.6版
23956 5
发布于 2024-6-19 15:45:35
by glukoz
V3.12视频
Uvpackmaster 3
Pack your UV maps with maximum efficiency
以最高效率打包您的 UV 贴图
Using the CPU and all GPUs in the system simultaneously!
同时使用系统中的CPU和所有GPU!
UVPackmaster is the most efficient UV packer out there in terms of packing on CPU, but it also provides a Cuda-accelerated variant of the algorithm. When running on a GPU, it significantly outperforms all other packers available.
就 CPU 上的打包而言,UVPackmaster 是最高效的 UV 打包器,但它还提供了 Cuda 加速的算法变体。当在 GPU 上运行时,它的性能明显优于所有其他可用的加壳器。
But what can be faster than running an algorithm on a GPU? Running it on the CPU and all GPUs in the system simultaneously! UVPackmaster will do exactly that to reduce the time needed to perform even the most advanced packing scenarios to seconds.
但是还有什么比在 GPU 上运行算法更快的呢?同时在系统中的 CPU 和所有 GPU 上运行!UVPackmaster 正是这样做的,以将执行最先进的打包方案所需的时间减少到几秒钟。
Not only packing efficiency
不仅仅是包装效率
Note that UVPackmaster does not only mean high performance – it also provides a lot of sophisticated packing functionalities not available in other UV packers. Visit our site for more information.
请注意,UVPackmaster 不仅意味着高性能,它还提供许多其他 UV 打包机所不具备的复杂打包功能。请访问我们的网站了解更多信息。
Not only a UV packing tool
不仅仅是UV包装工具
UVPackmaster 3 is a milestone that moves the tool towards more general UV applications. UVPackmaster is now not only a state-of-the-art UV packing solution – it also introduces an advanced UV aligning/stacking algorithm and other auxiliary tools, greatly simplifying your UV workflow.
UVPackmaster 3 是一个里程碑,它将该工具推向更通用的 UV 应用。UVPackmaster 现在不仅是最先进的 UV 打包解决方案 - 它还引入了先进的 UV 对齐/堆叠算法和其他辅助工具,大大简化了您的 UV 工作流程。
All these functionalities run with engine-acceleration for maximum efficiency.
所有这些功能均通过发动机加速运行,以实现最高效率。
Maximum flexibility for the most demanding users, thanks to the scriptable architecture.
得益于可编写脚本的架构,为最苛刻的用户提供了最大的灵活性。
UVPackmaster is not a black box anymore. We embedded Python into the newest engine release, giving you a possibility to code your own operation logic, perfectly adjusted to your own most demanding workflows.
UVPackmaster 不再是一个黑匣子。我们将 Python 嵌入到最新的引擎版本中,使您可以编写自己的操作逻辑,并完美地适应您自己最苛刻的工作流程。
参与人数 3元素币 +22 活跃度 +11 展开 理由
莲花落 + 9 + 5 打赏一个吧
山泉 + 9 + 1 太秀了吧?
xduoduo + 4 + 5 谢谢楼主分享,好人一生平安
人不付出牺牲,就无法得到任何回报。 想要得到什么,就必须付出同等的代价
a4224020a  发表于 2024-6-21 11:01:25
666666666666666666666666666666666
THT_61  发表于 2024-7-9 12:03:54
谢谢楼主分享~~~~~~~!!!!
dsj380581836  发表于 2024-8-20 17:55:22
爱你小小  发表于 2024-11-29 19:01:31
oyxjoyxj  发表于 2025-8-8 11:08:33
感谢分享!!!
