Geosim逼真行星宏观实时地形地貌Blender插件V1.4版
23995 6
发布于 2024-5-30 15:49:15
by Alex R Heskett
Geosim V1.4 | Photorealistic Planets (Eevee / Cycles)
Geosim V1.4 | 逼真的行星(Eevee / Cycles)
What is GeoSim?
什么是 GeoSim?
GeoSim is an add-on which allows the creation of photorealistic, realtime, customizable planets in a matter of seconds. Combined with a robust and easy to use shader nodegroup, GeoSim is a must-have for any 3D artist looking to create space/sci-fi scenes.
GeoSim 是一个附加组件,可以在几秒钟内创建逼真、实时、可定制的行星。与强大且易于使用的着色器节点组相结合,GeoSim 是任何想要创建太空/科幻场景的 3D 艺术家的必备工具。
  - Physically Based Volumetric Rendering
  - 基于物理的体积渲染
Using a multitude of advanced techniques, GeoSim can create photorealistic planetary atmospheres at a much higher quality and speed than Cycles or Eevee. Attributes such as density, thickness, and color can all be controlled with in the GeoSim shader.
使用多种先进技术,GeoSim 可以比 Cycles 或 Eevee 更高的质量和速度创建逼真的行星大气层。密度、厚度和颜色等属性都可以在 GeoSim 着色器中控制。
  - Image-based Clouds
- 基于图像的云
In order to add an extra layer of realism, GeoSim includes real-time, shadow-casting clouds. Just plug in your image/procedural texture and the shader will automatically convert it into semi-3D, volumetric clouds.
为了增加额外的真实感,GeoSim 包括实时阴影投射云。只需插入图像/程序纹理,着色器就会自动将其转换为半 3D 体积云。
  - Full Texture Support
  - 完整纹理支持
GeoSim comes fully equipped to handle all required textures, including albedo, roughness, specular, normal, and emission. All image textures can be accessed easily through
a separate nodegroup, allowing them to be modified at any
time.
GeoSim 配备齐全,可以处理所有所需的纹理,包括反照率、粗糙度、镜面反射、法线和发射。所有图像纹理都可以通过轻松访问
一个单独的节点组,允许随时修改它们
时间。
For instruction on using the addon, see the documentation section.
有关使用插件的说明,请参阅文档部分。
参与人数 3元素币 +16 活跃度 +6 展开 理由
yangmie + 8 + 4 这是我能看的吗?
欠钱不想还... + 4 + 1 元素给力
kbydfhy + 4 + 1 超赞
人不付出牺牲,就无法得到任何回报。 想要得到什么,就必须付出同等的代价
GPT-绘图小能手  发表于 2023-9-5 10:11:17
Geosim是一个Blender插件,用于创建逼真的行星宏观实时地形和地貌。它包括图像云和完整的纹理支持。你可以通过提供的链接下载插件。
GeoSim includes real-time, shadow-casting clouds that add an extra layer of realism to your scenes. You can plug in your own image or procedural texture, and the shader will automatically convert it into semi-3D, volumetric clouds.
The plugin also comes with full texture support, allowing you to handle all required textures such as albedo, roughness, specular, normal, and emission. All image textures can be easily accessed and modified at any time through a separate node group.
For instructions on how to use the addon, please refer to the documentation section provided in the link.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
Teny  发表于 2023-9-5 18:20:42
谢谢楼主分享!!!
科科科  发表于 2023-12-4 17:53:23
六块腹肌  发表于 2024-5-31 11:04:16
谢谢楼主分享~~~~~~~!!!!
m345342010  发表于 2024-9-26 18:14:10
66666
