【Blender】Fast Sculpt Assistant快速雕刻助手
132 4
发布于 2023-10-16 10:14:10
↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑下载地址在这儿
该插件使得一键轻松使用各种雕刻操作。
消除在键盘上移动手指的繁琐过程。这对于手写板用户尤其有效。虽然笔选项卡上的快捷按钮数量有限,但您将能够在不将左右手尽可能离开数位板的情况下进行雕刻。---如何使用---在雕刻模式下,按下“U”键时将打开菜单(默认情况下,您可以从首选项中进行更改)。按同一键关闭,不执行任何操作。菜单与以下部分分开。
1:更改画笔半径 / 2:更改画笔强度 / 3:打开画笔设置 / 4:打开画笔纹理 / 5:打开画笔描边 / 6:打开画笔描边
7: Open brush context / 8: Open mask pie / 9: Open face sets pie / 10: Open set pivot pie / 11: Open auto masking pie / 12: Open remesh panel
13: View from the top / 14: View from the back / 15: View from the right / 16: View from the bottom / 17: View from the left / 18: View from the front
19: Remesh with initial size(editable from preferences) / 20: Remesh / 21: Sample detail size and remesh
22: Remesh with voxel size times multiplier2(editable from preferences) / 23: Remesh with voxel size times multiplier1(editable from preferences)
24: Remesh with voxel size divided by multiplier1 / 25: Remesh with voxel size divided by multiplier2 / 26: Create new primitive object(some paraneters are editable from preferences)
27: Make backup / 28: Transfer mode / 29: Switch mode / 30: Toggle erase alpha / 31: Mirror Z / 32: Mirror Y / 33: Mirror X / 34: Next matcap / 35: Previous matcap
36: Toggle favorite matcap / 37: Show or hide Wireframe of active object / 38: X-ray / 39: Show or hide active object / 40: Show or hide collection set by UI
  • When you press "27: Make backup", active object duplicated and move to collection named OBJECTNAME_backup that is automatically created and hide from viewport.
  • "28: Transfer mode" is to switch object with keeping mode sculpt.(same as shortcut Alt + Q)
  • "30: Toggle erase alpha" is switch between active blending mode and erase alpha. This only works when active brush is Paint.
  • 要为“36:切换最喜欢的 matcap”设置最喜欢的 matcap,请在更改要注册的 matcap 后,从视口着色面板中按“SetFavMatcap1”和“SetFavMatcap2”。
  • 要为“40:显示或隐藏 UI 设置的集合”设置集合,请在大纲视图中右键单击要设置的集合,然后按将所选集合设置为目标按钮。
设置
在首选项中,有一些参数。
安装
  • 下载 zip 文件。
  • 转到首选项,打开附加组件选项卡。
  • 单击“安装”并选择 zip 文件。
  • 选中其名称旁边的框以启用它。
更新1.0.0-首次发布
参与人数 3元素币 +11 活跃度 +9 展开 理由
andywater1... + 4 + 2
AirLee-Wei + 4 + 3 如此优秀,不顶对比起楼主
bass01 + 3 + 4 卷起来
要好好学习哦
GPT-山姆奥特曼  发表于 2023-9-5 17:17:50
【Blender】Fast Sculpt Assistant是一款用于快速雕刻的助手工具。
您可以通过以下步骤安装它:
1. 下载压缩文件(zip文件)。
2. 打开Blender软件,并进入首选项。
3. 切换到“附加组件”选项卡。
4. 点击“安装”按钮,然后选择下载的zip文件。
5. 在其名称旁边的复选框中勾选,以启用该助手工具。
Update1.0.0-首次发布
Translation:
【Blender】Fast Sculpt Assistant is a helper tool for fast sculpting.
You can install it by following these steps:
1. Download the zip file.
2. Open Blender and go to preferences.
3. Switch to the "Add-ons" tab.
4. Click on "Install" and select the downloaded zip file.
5. Check the box next to its name to enable it.
Update 1.0.0 - First release.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
大西几  发表于 2023-9-5 17:45:48
下载地址呢
仰空越梦  发表于 2023-9-5 23:21:19
感谢分享~!
花落  发表于 2023-9-6 10:00:18
小手一抖,积分到手!
