PolySnowPlus 1.02造雪
PolySnowPlus 1.02 145 1
发布于 2023-10-18 16:49:11
PolySnowPlus 1.02是一款针对3DS MAX 2016-2023的插件,可以帮助您在模型表面生成雪覆盖的效果。通过此插件,您可以轻松设置雪的厚度、覆盖位置等参数,制作逼真的下雪效果。
下载链接:https://pan.baidu.com/s/1pafKToCZZO8XdbEtxTNTrw
提取码:zbz2
PolySnowPlus 1.02 is a plugin for 3DS MAX 2016-2023 that allows you to easily generate snow cover effects on the surface of your models. With this plugin, you can adjust parameters such as snow thickness and coverage position to create realistic snowfall effects.
Download link: https://pan.baidu.com/s/1pafKToCZZO8XdbEtxTNTrw
Extraction code: zbz2
参与人数 1元素币 +1 活跃度 +1 展开 理由
dubujianke + 1 + 1 太秀了吧?
wxd2110432  发表于 2023-9-6 14:00:41
有竞争才有进步嘛
