[翻译] : 这是我为新的 "Mega Assembly" 流程构建并布景环境的 Megascans 组合包。我优化了管道,使其适用于游戏开发,并且可以直接拖放到游戏中。使用这种方法,你可以在几分钟内轻松创建这样的环境。在这个包中,我特别构建了管道,协助 Jack Mckelvie 制作了一些场景组件,对每个环境镜头进行了优化、布景,还完成了所有照明和后期处理。
我和 Jack Mckelvie 密切合作,他为这个包制作了大部分组件。请在这里查看他的作品:[Jack Mckelvie 的工作链接]。
Here's a Megascans assembly pack that I built and set dressed the environment for the new 'Mega Assembly' workflow. I built and optimized the pipeline to be game ready and drag and drop ready into your game. With this method, you can easily build an environment like this in literal minutes.For this pack I specifically built the pipeline, helped Jack Mckelvie create some of the diorama assemblies, optimized, set dressed each environment shot, and did all the lighting and post processing.I worked closely with Jack Mckelvie, he built most of the assemblies for this pack. Please check out his work here:
