链接:https://pan.baidu.com/s/1RyPB51HcPJpQfkzH8DhUpA?pwd=zddu
提取码:zddu
油管:Toonkit 1.3 - Getting Starting with Toonkit - YouTube
THE MOST REQUESTED FEATURES FOR NPR AND EXPRESSIVE ARTISTS!ToonKit for Cycles is the In-House solution developed by Cogumelo Softworks for rendering NPR, PSR, and Stylish Renderings with Cycles. For those who work with Anime, Technical, Arch Viz, Engineering, and Expressive Art Toonkit for Cycles, you need just that.
NEW NODES FOR YOUR CREATIVITY!The way that Cycles work today makes it unfeasible to work with NPR rendering. We implement many requested nodes that allow users to make stylish renderings with cycles. Toonkit for Cycles is an add-on that implements lots of new OSL shader nodes that are seamlessly integrated into Cycles and Blender.
LIGHTNING FAST INTERACTION!Toonkit for Cycles is based on OSL shaders that are fully interactive and integrated into Cycles Node System and Blender’s Viewport. ToonKit shaders are Lightning Fast and most will converge to noiseless production quality images in only 4~32 samples!
POWER TO THE ARTISTS!In Toonkit all node outputs are Colors, it includes Shadings, Shadows, and Specular that you can mix and operate as you wish. No more Mix Restriction for your creativity!
FACE PAINT TOOLSToonkit has integrated a new System for Face Paint using Vertex Colors in Edit Mode. It's designed to speed up the paint workflow for cartoon styles.
RAYTRACE-BASED LINE RENDER FOR CYCLESToonkit for Cycles implements two fast and stable Line Rendering nodes for Cycles with controls of the influence of Normal, Depth, Object Id, Silhouette, and Vertex Color.
