Blender汽车交通工具绑定插件 VRF – Vehicle Rig Factory Plus V0.1.2
93 1
发布于 2024-2-26 13:33:29
youtube展示视频:https://www.youtube.com/watch?v=8yHndb1kJos
下载地址:V4.0.8链接: https://pan.baidu.com/s/1nN_rezWt0QxkDatuaKx-Qg?pwd=wq83 提取码: wq83
                 V0.1.2链接: https://pan.baidu.com/s/1SjSbwZatGWSy-pOSoACd8w?pwd=ve3g 提取码: ve3g
原文:vehicle Rig Factory Plus is an addon that helps to build your own vehicle rig, this addon is very flexible and can do rig many types of vehicles, put in or put out a system whatever is suitable for your needs, this addon already tasted in real production and solved many problems in vehicle rig, designing for cartoon tasted, this addon has features to help Rigger to solved essential technical with a new method that only found in new blender version start from Blender 2.9+ until Blender 3.0+, such as make wheel flat tire, wheel tank, detach wagon, and use new constraints.
翻译:vehicle Rig Factory Plus是一个插件,可以帮助您构建自己的车辆装备,该插件非常灵活,可以装配多种类型的车辆,放入或推出适合您需求的系统,该插件已经在实际生产中试用并解决了车辆装备中的许多问题,为卡通产品设计, 该插件具有帮助装配工用新方法解决基本技术问题的功能,该方法仅在从blender 2.9+到Blender 3.0+的新Blender版本中出现,例如制作轮胎漏气轮胎、车轮油箱、分离货车以及使用新的约束条件。
参与人数 2元素币 +5 活跃度 +5 展开 理由
小毒爷 + 2 + 3 看起来不错
玖阑枢 + 3 + 2 看看
Teny  发表于 2024-2-4 20:18:06
谢谢楼主分享!!!
