【Blender插件】Random Flow v2.9.5-随机建模流网格形状细节生成插件...
86 2
发布于 2024-2-29 18:15:59
插件类型: Blender
版本信息: v2.9.5
软件版本要求: Blender 3.6, 4.0
官网地址: https://blendermarket.com/products/random-flow
链接:https://pan.baidu.com/s/1VWg9o2hYuRNAhRwTqw95gQ?pwd=8473
提取码:8473
油管:https://www.youtube.com/watch?v=RKnrCqHT5_Y
Random Flow is a random mesh generator designed for fast and easy hard surface prototyping and concept art. This a fast changing add-on with lots of new functionalities in the future.
Use code: bgdiscount25 for 25% discount for the rest of my product after purchasing a single one.
I want to thank Piero Desopo for testing the add-on, finding bugs and improvements. He’s also responsible for some of the cool renders using the plugin. Go check out his art @ http://phoenixart.com
Read the documentation included in the zip file for the installation instruction and further understanding of all the functions in the add-on.
This product is also available in the Creative Bundle and other add-ons if you want to purchase that instead.
FEATURES:
Random Loop Extrude – generates random extrusions from loop objects to create interesting shapes and details.
Random Panels – creates paneling details or extrusions whose height can also be randomized.
Random Axis Extrude - generates random extrusions from faces in the XYZ directions respectively.
Random Cells– randomly creates faces in cell configurations.
Random Scatter – randomly scatters objects or collection objects on surface points in the mesh.
Random Tubes – generates random tubes on selected faces of a mesh.
Random Cables - generates random catenary cables from selected faces.
Random Vertex Color - generates random vertex color which can be limited to objects, face islands and selections.
Random Animation - generates random transform animations in the xyz axis.
Flanges/Couplings - generates flanges or couplings on curve objects or on results of random tubes and random cables.
Panel Screws - generates screw design objects on selected faces.
Panel Cloth - generate cloth physics.
Grid Project - projects grid based cuts on selected faces for even quad topology.
Quad Slice - makes quads out of ngons by cutting lines by their vertices.
Auto Mirror - a fast intuitive auto mirror function.
Merge Functions - merges objects via boolean or basic join.
Mesh Data Save Feature - saves mesh data for backup or reuse.
The results from these operators offers a far more convincing result than most greeble functions. You can have designs render ready in mere minutes instead of spending hours manually designing objects.
Building a detailed scene can stress out even the most disciplined artists. With Random Flow you can skip most of the modeling pipeline and just focus on the design and shape.
And the best part about this is the randomized meshes are separate objects so the whole process becomes non-destructive.
So relax and have fun making those cool renders while you charge your creative juices at the same time.
The Random Flow add-on also includes a quadify ngon, set origin for multiple selection and a clean up tool.
The default hotkey is Shift+Q in object or edit mode. Some functions will only appear in edit mode.
* This is a one time purchase and all updates are free.
参与人数 4元素币 +18 活跃度 +11 展开 理由
amenjuzi + 7 + 4 想要更多
tutuzi + 5 + 1 谢谢楼主分享,好人一生平安
tianmingmi... + 2 + 5 这就是大佬的世界嘛
fanlai + 4 + 1 给力
fqvzkjguzd  发表于 2024-2-6 13:30:51
给力喲
