下载地址:https://pan.baidu.com/s/1-ICPFRCJmdH0jfUnfj1OMA?pwd=v9xy 提取码: v9xy
youtube展示视频:https://www.youtube.com/watch?v=g0_YiAJwlsE
原文:
About BakeMaster
We all know that models with loads of geometry require way more computer power to render. On the other hand, lowpoly model is easier to handle, and you can transfer high-resolution details onto it. This is called texture baking, and BakeMaster delivers everything you need to get it fast and of the highest quality.Introduction
Welcome to BakeMaster, a powerful and feature-packed baking solution created for Blender.关于烘焙大师
我们都知道带有大量几何图形的模型需要更多的计算机能力来渲染。另一方面,lowpoly模型更容易处理,您可以将高分辨率细节传输到它上面。这被称为纹理烘焙,BakeMaster提供您快速获得最高质量的一切所需。介绍
欢迎使用BakeMaster,这是一款为Blender开发的功能强大的烘焙解决方案。
Along with the BakeMaster’s intuitive and convenient workflow baking process becomes a pleasure. The addon is for users who can’t stand wasting time and yearn for most functionality with professional and cutting-edge baking features.随着烘焙大师直观便捷的工作流程,烘焙过程成为一种享受。该插件适用于无法忍受浪费时间并渴望拥有专业和尖端烘焙功能的大多数功能的用户。
With it, baking feels like a new book. Everything is right in your hands, under control, and easy to access and configure. Created by artists, BakeMaster is straightforward and comfortable to use, yet lands with numerous tweaks and toggles to fully meet your ultimate texture baking preferences.Baking with BakeMaster takes only three steps:Setup Objects
Choose Maps
Hit Bake!
An unlimited number of objects and maps to bake, each driven by unique or grouped settings – carry it all out with BakeMaster!Why creators choose BakeMaster
Baking standardly with Blender is ok. But what about baking dozens of models with a desire to have different settings, maps, masks, or view how baked maps will look like, make sure your objects have a correct shading set up, perform a Channel Pack, or any other highly requested task? It can easily lead to losing valuable time. Here is when BakeMaster comes into play. It can manage all of that in seconds and with a few clicks!有了它,烘焙就像一本新书。一切尽在掌握之中,尽在掌握之中,并且易于访问和配置。BakeMaster由艺术家创作,简单易用,但具有众多调整和切换功能,可完全满足您的最终纹理烘焙偏好。使用BakeMaster烘焙只需三个步骤:设置对象
选择地图
点击烘焙!
无限数量的要烘焙的对象和贴图,每个都由独特的或分组的设置驱动-使用BakeMaster完成所有任务!创作者选择烘焙大师的原因
用搅拌机标准烘烤就可以了。但是,如果烘焙几十个模型,希望拥有不同的设置、贴图、遮罩或查看烘焙后的贴图的外观,确保对象具有正确的着色设置,执行通道包或任何其他高要求的任务,该怎么办呢?这很容易导致失去宝贵的时间。这就是面包师发挥作用的时候。只需点击几下鼠标,它就可以在几秒钟内完成所有这些工作!
Have complex materials? Never worry about the nodes again: toggle a couple of settings, and BakeMaster will configure it all for you. Are Cycles maps gone? Not just yet – simple UI and manageable settings make it feel cool.For whom is BakeMaster有复杂的材料?再也不用担心节点了:切换几个设置,BakeMaster就会为您配置好。循环地图消失了吗?还没有——简单的用户界面和易于管理的设置让它感觉很酷。BakeMaster是给谁的
Whether you come from Game Dev, prepare and texture your models, or bake for fun, BakeMaster is for you.The addon fits beginners as well as proficient users. Comfortable creation tools saving you time and making your artistic thoughts never jump out of the boat are vital.Map preview
Image Editor[tr]Key features
[tr]Bake an unlimited number of objects and maps.
[tr]Drive with 36 different map types.
[tr]Match all lowpolies, highpolies, decals, and cages in a single click.
[tr]Enhance your texturing with loads of special maps and masks.
[tr]Outstanding configuration, customize everything.
[tr]Preview maps before baking, real-time.
[tr]UDIMs? No problem.
[tr]Texture Sets. Bake multiple objects onto the same images.
[tr]Channel Pack maps the way you prefer.
[tr]Group objects into bake jobs.
[tr]Turn on Denoising and Supersample AA, for UDIMs too.
[tr]ACES out of the box, Default Rules and Color Management for pro artists.
[tr]Bake Decals separately and onto objects.
[tr]Bake from and to Vertex Colors.
[tr]Fastest ID Map.
[tr]Save time with presets and execute any task on the go.
[tr]Get the best results.
[tr]Channel Pack maps the way you prefer无论您是来自游戏开发部门,准备并制作模型纹理,还是为了娱乐而烘焙,BakeMaster都适合您。该插件适合初学者和熟练用户。舒适的创作工具节省您的时间并使您的艺术思想永远不会跳出船外是至关重要的。[tr]关键特征
[tr]烘焙无限数量的对象和贴图。
[tr]驾驶36种不同的地图类型。
[tr]只需单击一下鼠标即可匹配所有低地、高地、贴花和笼子。
[tr]使用大量的特殊贴图和遮罩来增强纹理效果。
[tr]出众的配置,定制一切。
[tr]烘焙前实时预览地图。
[tr]乌迪姆?没问题。
[tr]纹理集。将多个对象烘焙到相同的图像上。
[tr]频道包以您喜欢的方式映射。
[tr]将对象分组到烘焙作业中。
[tr]为UDIMs打开去噪和超级采样AA。
[tr]专业艺术家的开箱即用、默认规则和色彩管理。
[tr]单独烘烤贴花并贴到物体上。
[tr]烘焙自和至顶点颜色。
[tr]最快的身份证地图。
[tr]通过预设节省时间,并在旅途中执行任何任务。
[tr]获得最佳结果。
[tr]烘焙无限数量的对象和贴图
[tr]驾驶36种不同的地图类型
[tr]只需单击一下鼠标即可匹配所有低区、高区、贴花和笼子
[tr]出色的配置,定制一切
[tr]烘焙前实时预览地图
[tr]乌迪姆?没问题
[tr]频道包以您喜欢的方式映射
