element3ds.com
SD-材质作品 Travel Materials - DALL-E2 _ Substance
33261
1
[翻译] : 使用手机旅行时拍摄的照片制作的素材!通常,你可以在街上看到材料艺术家,他们会在地面或墙壁上拍摄特写照片。我过去几年积累了大量照片,最近有了Substance Sampler和DALL-E2的经验,这是个好时机来利用它们。我对Sampler的效果印象深刻,DALL-E2填补空白的能力仍然让我惊讶。我已经包含了源照片、偏移和输出,你可以看到它做了什么(输出有额外的偏移,来自第二次接缝修复)。再次使用Gigapixel AI来放大DALL-E2的结果,因为它们目前锁定在1k输出。大部分结果在Designer中几乎没有编辑,但对于木墙,我创建了一个树干的遮罩,填充了一些圆角渐变,以与法线和高度融合,达到理想效果。这些大部分需要大约45分钟到一个小时完成。组合它们真的很有趣!
Materials created from photos I have taken with my phone while travelling!
You can usually spot a Material Artist as they are the one taking close up photos of the ground or walls in the street.
I_ve gathered a lot of photos over the last few years, and with my recent experience with Substance Sampler, and DALL-E2 it was a great time to put some to use!
I_m very impressed with the results from Sampler and still amazed at DALL-E2_s ability to fill in the gaps. I have included the source photos, offset and output so you can see what it has done (The output has an extra offset from the 2nd pass of seam fixing). Again I used Gigapixel AI to upscale the results from DALL-E2 as they are currently locked at 1k outputs.
Most of the results have minimal edits in Designer, though for the Wood Wall I created a mask for the logs and flood-filled some rounded gradients to blend with the normal and height to get the proper look. These mostly took around 45 minutes to an hour each.
Had a lot of fun putting them together!
参与人数 3 元素币 +15 活跃度 +10
Artstation:https://www.artstation.com/stanbrown
fengyu123  发表于 2024-6-22 18:58:40
Stan_Brown 实名
资深材质师
