[Shader/渲染] 描边 Outline
查看:909 |回复:8 | 2024-8-12 18:29:35
99元素币
  1. Properties
  2.     {
  3.         _MainTex("MainTex", 2D) = "white"{}
  4.         _Diffuse("Color", Color) = (1,1,1,1)
  5.         _Outline("Outline", Range(-2, 2)) = 0.1
  6.         _OutlineColor("OutlineColor", Color) = (0,0,0,0)
  7. }
  8.     SubShader
  9.     {
  10.         Tags {
  11.             "RenderType" = "Opaque"
  12.         }
  13.         LOD 100
  14.        Pass
  15.         {
  16.             Name "OutLine"
  17.             Cull Front
  18.
  19.             CGPROGRAM
  20.             #pragma vertex vert
  21.             #pragma fragment frag
  22.             #include "UnityCG.cginc"
  23.
  24.             float _Outline;
  25.             fixed4 _OutlineColor;
  26.             struct v2f
  27.             {
  28.                 float4 vertex : SV_POSITION;
  29.             };
  30.
  31.             v2f vert (appdata_base v)
  32.             {
  33.                 v2f o;
  34.                 v.vertex.xyz += v.normal * _Outline;
  35.                 o.vertex = UnityObjectToClipPos(v.vertex);
  36.                 return o;
  37.             }
  38.
  39.             float4 frag (v2f i) : SV_Target
  40.             {
  41.                 return float4(_OutlineColor.xyz, 1);
  42.             }
  43.             ENDCG
  44.         }
  45.         Pass
  46.         {
  47.             Cull Back
  48.             //Blend Zero One
  49.             CGPROGRAM
  50.             #pragma vertex vert
  51.             #pragma fragment frag
  52.             #include "UnityCG.cginc"
  53.             #include "Lighting.cginc"
  54.
  55.             sampler2D _MainTex;
  56.             float4 _MainTex_ST;
  57.             fixed4 _Diffuse;
  58.             struct v2f
  59.             {
  60.                 float4 vertex : SV_POSITION;
  61.                 float2 uv: TEXCOORD0;
  62.                 fixed3 worldNormal : TEXCOORD1;
  63.                 float3 worldPos : TEXCOORD2;
  64.             };
  65.             v2f vert (appdata_base v)
  66.             {
  67.                 v2f o;
  68.                 o.vertex = UnityObjectToClipPos(v.vertex);                         //转换坐标到裁剪空间
  69.                 o.worldNormal = UnityObjectToWorldNormal(v.normal);                //物体法线转世界法线
  70.                 o.worldPos = mul(unity_ObjectToWorld,v.vertex);                    //顶点位置信息转世界位置信息
  71.                 o.uv = TRANSFORM_TEX(v.texcoord,_MainTex);
  72.                 return o;
  73.             }
  74.             fixed4 frag (v2f i) : SV_Target
  75.             {
  76.                 fixed3 ambient = UNITY_LIGHTMODEL_AMBIENT.xyz;                     //环境光
  77.                 fixed4 albedo = tex2D(_MainTex,i.uv);
  78.                 //漫反射
  79.                 fixed3 worldLightDir = UnityWorldSpaceLightDir(i.worldPos);        //求光源方向
  80.                 float difLight = dot(worldLightDir,i.worldNormal) * 0.5 + 0.5;
  81.                 fixed3 diffuse = _LightColor0.rgb * albedo.rgb * _Diffuse.rgb * difLight;
  82.                 //fixed3 viewDir = normalize(UnityWorldSpaceViewDir(i.worldPos));
  83.                 //fixed3 halfDir = normalize(worldLightDir + viewDir);
  84.                 fixed3 color = diffuse + ambient ;
  85.                 return fixed4(color,1);
  86.             }
  87.             ENDCG
  88.         }
  89.     }
点击此处复制文本
Outline值改为负的也不能出现带有贴图的渲染 我想知道问题出在哪
【全场最佳】会公开答案中的下载地址,如果您希望答案是收费内容,请在正确区【发帖】,并回复帖子地址。
2024-8-12 18:29:35
8个回答,把该问题分享到群,邀请大神一起回答。
虽然不知道这行什么意思
2024-8-13 17:19:40   回复
 赞 赞 2
2024-8-14 15:04:20   回复
从业不识微元素,做遍项目也枉然
2024-8-15 00:55:19   回复
2024-8-21 10:05:29   回复
(⊙o⊙)…
2024-8-27 10:12:04   回复
(⊙o⊙)…
2024-9-3 11:56:57   回复
顶个贴 学习一波 感谢大佬分享
2024-10-24 00:25:59   回复
ShaderOutlinePass
