今天为大家分享一下,如何做一个六角形花纹效果的小Demo。
欢迎加我的学习交流群: 575561285
好吧!废话不多讲,我直接上图操作!
1.新建一个Unity3d 项目,新建一个CameraFilterPack_AAA_SuperHexagon.shader文件。
- Shader "CameraFilterPack/AAA_Super_Hexagon" {
- Properties
- _MainTex ("Base (RGB)", 2D) = "white" {}
- _TimeX ("Time", Range(0.0, 1.0)) = 1.0
- _Distortion ("_Distortion", Range(0.0, 1.0)) = 0.3
- _ScreenResolution ("_ScreenResolution", Vector) = (0.,0.,0.,0.)
- _Value ("_Value", Range(0.2, 10.0)) = 1
- _HexaColor ("_HexaColor", Color) = (1,1,1,1)
- _BorderSize ("_BorderSize", Range(-0.5, 0.5)) = 0.0
- _BorderColor ("_BorderColor", Color) = (1,1,1,1)
- _SpotSize ("_SpotSize", Range(0, 1.)) = 0.5
- _AlphaHexa ("_AlphaHexa", Range(0.2, 10.0)) = 1
- _PositionX ("_PositionX", Range(-0.5, 0.5)) = 0.0
- _PositionY ("_PositionY", Range(-0.5, 0.5)) = 0.0
- _Radius ("_Radius", Range(0, 1.)) = 0.5
- SubShader
- Pass
- ZTest Always
- CGPROGRAM
- #pragma vertex vert
- #pragma fragment frag
- #pragma fragmentoption ARB_precision_hint_fastest
- #pragma target 3.0
- #include "UnityCG.cginc"
- uniform sampler2D _MainTex;
- uniform float _TimeX;
- uniform float _Distortion;
- uniform float4 _ScreenResolution;
- uniform float _Value;
- uniform float _BorderSize;
- uniform float4 _BorderColor;
- uniform float4 _HexaColor;
- uniform float _AlphaHexa;
- uniform float _PositionX;
- uniform float _PositionY;
- uniform float _Radius;
- uniform float _SpotSize;
- struct appdata_t
- float4 vertex : POSITION;
- float4 color : COLOR;
- float2 texcoord : TEXCOORD0;
- struct v2f
- half2 texcoord : TEXCOORD0;
- float4 vertex : SV_POSITION;
- fixed4 color : COLOR;
- v2f vert(appdata_t IN)
- v2f OUT;
- OUT.vertex = mul(UNITY_MATRIX_MVP, IN.vertex);
- OUT.texcoord = IN.texcoord;
- OUT.color = IN.color;
- return OUT;
- float hexDist(float2 a, float2 b){
- float2 p = abs(b-a);
- float s = 0.5;
- float c = 0.8660254;
- float diagDist = s*p.x + c*p.y;
- return max(diagDist, p.x)/c;
- float2 nearestHex(float s, float2 st){
- float h = 0.5*s;
- float r = 0.8660254*s;
- float b = s + 2.0*h;
- float a = 2.0*r;
- float m = h/r;
- float2 sect = st/float2(2.0*r, h+s);
- float2 sectPxl = fmod(st, float2(2.0*r, h+s));
- float aSection = fmod(floor(sect.y), 2.0);
- float2 coord = floor(sect);
- if(aSection > 0.0){
- if(sectPxl.y < (h-sectPxl.x*m)){
- coord -= 1.0;
- else if(sectPxl.y < (-h + sectPxl.x*m)){
- coord.y -= 1.0;
- else{
- if(sectPxl.x > r){
- if(sectPxl.y < (2.0*h - sectPxl.x * m)){
- coord.y -= 1.0;
- else{
- if(sectPxl.y < (sectPxl.x*m)){
- coord.y -= 1.0;
- else{
- coord.x -= 1.0;
- float xoff = fmod(coord.y, 2.0)*r;
- return float2(coord.x*2.0*r-xoff, coord.y*(h+s))+float2(r*2.0, s);
- inline float2 screenDistort(float2 uv)
- uv -= float2(.5,.5);
- uv = uv*1.2*(1.0/1.2+2.*uv.x*uv.x*uv.y*uv.y);
- uv += float2(.5,.5);
- return uv;
- float noise2(float n)
- return lerp(0,0.5,smoothstep(0.0,0.5,+fmod(n+0.5,1.0)));
- float4 frag (v2f i) : COLOR
- float2 uv = i.texcoord.xy;
- float s = _Value * _ScreenResolution.x/160.0;
- float2 nearest = nearestHex(s, i.texcoord.xy * _ScreenResolution.xy);
- float4 texel = tex2D(_MainTex, nearest/_ScreenResolution.xy);
- float4 texel2 = tex2D(_MainTex, uv);
- uv = screenDistort(uv);
- float2 uv2;
- uv2 = uv.yy+float2(0.1*sin(_TimeX/3)*5,0.1*sin(_TimeX/5)*5);
- float3 video = tex2D(_MainTex,uv2).rgb;
- float vigAmt = 2.+.3*sin(15+5.*cos(5.));
- float vignette = (1.-vigAmt*(uv.y-.5)*(uv.y-.5))*(1.-vigAmt*(uv.x-.5)*(uv.x-.5));
- video += (12.+fmod(uv.y*10.+_TimeX,1.))/13.;
- float2 center = float2(_PositionX,_PositionY);
- float dist2 = 1.0 - smoothstep( _Radius,_Radius+0.15*_SpotSize, length(center - uv));
- float dist = hexDist(i.texcoord.xy * _ScreenResolution.xy, nearest);
- float luminance = (texel.r + texel.g + texel.b)/3.0;
- float interiorSize = s*_BorderSize;//*(1-dist2*2);
- float interior = 1.0 - smoothstep(interiorSize-1.0, interiorSize, dist);
- float4 result;
- result.rgb=lerp(_BorderColor.rgb,texel.rgb,interior);
- float mem=1-noise2(_TimeX/4+uv.x);
- result.rgb+=float3(mem,mem,mem);
- result.rgb*=_HexaColor.rgb;
- result.rgb/=video.rgb/2;
- result /= vignette*2;
- result.rgb=lerp(result.rgb,texel2.rgb,dist2);
- result.rgb=lerp(result.rgb,texel2.rgb,1-_AlphaHexa);
- result.a=1.0;
- return float4(result);
- ENDCG
点击此处复制文本
2.我们新建一个CameraFilterPack_AAA_SuperHexagon.cs组件 ,并且直接附加在摄像机对象上。
- using UnityEngine;
- [ExecuteInEditMode]
- [AddComponentMenu ("Camera Filter Pack/AAA/Super Hexagon")]
- public class CameraFilterPack_AAA_SuperHexagon : MonoBehaviour {
- #region Variables
- public Shader SCShader;
- [Range(0.0f, 1.0f)]
- public float _AlphaHexa = 1.0f;
- private float TimeX = 1.0f;
- private Vector4 ScreenResolution;
- private Material SCMaterial;
- [Range(0.2f, 10.0f)]
- public float HexaSize = 2.5f;
- public float _BorderSize = 1.0f;
- public Color _BorderColor = new Color (0.75f, 0.75f, 1, 1);
- public Color _HexaColor = new Color (0, 0.5f, 1, 1);
- public float _SpotSize = 2.5f;
- public static float ChangeBorderSize = 1.0f;
- public static Color ChangeBorderColor;
- public static Color ChangeHexaColor;
- public static float ChangeSpotSize = 1.0f;
- public static float ChangeAlphaHexa = 1.0f;
- public static float ChangeValue;
- public Vector2 center = new Vector2(0.5f,0.5f);
- public float Radius = 0.25f;
- public static Vector2 Changecenter;
- public static float ChangeRadius;
- #endregion
- #region Properties
- Material material
- get
- if(SCMaterial == null)
- SCMaterial = new Material(SCShader);
- SCMaterial.hideFlags = HideFlags.HideAndDontSave;
- return SCMaterial;
- #endregion
- void Start ()
- Changecenter = center;
- ChangeRadius = Radius;
- ChangeValue = HexaSize;
- ChangeAlphaHexa = _AlphaHexa;
- ChangeBorderSize = _BorderSize;
- ChangeBorderColor = _BorderColor;
- ChangeHexaColor = _HexaColor;
- ChangeSpotSize = _SpotSize;
- SCShader = Shader.Find("CameraFilterPack/AAA_Super_Hexagon");
- if(!SystemInfo.supportsImageEffects)
- enabled = false;
- return;
- void OnRenderImage (RenderTexture sourceTexture, RenderTexture destTexture)
- if(SCShader != null)
- TimeX+=Time.deltaTime;
- if (TimeX>100) TimeX=0;
- material.SetFloat("_TimeX", TimeX);
- material.SetFloat("_Value", HexaSize);
- material.SetFloat("_PositionX", center.x);
- material.SetFloat("_PositionY", center.y);
- material.SetFloat("_Radius", Radius);
- material.SetFloat("_BorderSize", _BorderSize);
- material.SetColor("_BorderColor", _BorderColor);
- material.SetColor("_HexaColor", _HexaColor);
- material.SetFloat("_AlphaHexa", _AlphaHexa);
- material.SetFloat("_SpotSize", _SpotSize);
- material.SetVector("_ScreenResolution",new Vector4(sourceTexture.width,sourceTexture.height,0.0f,0.0f));
- Graphics.Blit(sourceTexture, destTexture, material);
- else
- Graphics.Blit(sourceTexture, destTexture);
- void OnValidate()
- ChangeValue=HexaSize;
- Changecenter=center;
- ChangeRadius=Radius;
- ChangeBorderSize=_BorderSize;
- ChangeBorderColor=_BorderColor;
- ChangeHexaColor=_HexaColor;
- ChangeSpotSize=_SpotSize;
- ChangeAlphaHexa=_AlphaHexa;
- // Update is called once per frame
- void Update ()
- if (Application.isPlaying)
- HexaSize = ChangeValue;
- center = Changecenter;
- Radius = ChangeRadius;
- _BorderSize = ChangeBorderSize;
- _BorderColor = ChangeBorderColor;
- _HexaColor = ChangeHexaColor;
- _SpotSize = ChangeSpotSize;
- _AlphaHexa = ChangeAlphaHexa;
- #if UNITY_EDITOR
- if (Application.isPlaying!=true)
- #endif
- void OnDisable ()
- if(SCMaterial)
- DestroyImmediate(SCMaterial);
点击此处复制文本
3.因为操作比较简单,我们直奔终点看效果吧!
