CG视频教程 [3D建模] 【Rhino】Alexandre《使用 Rhino 3D 制作复古跑车》(中英双字)
255
4
视频教程
CG教程: 建模|雕刻 材质|节点
语音: 英语
字幕: 双语字幕 机翻字幕
清晰度: 高清 720P
版权声明: 【公共内容】
价格:400元素币(或40余额) 百度网盘 销售总额:0元素币 购买人数:0
尊敬的游客 ,本内容需要支付 400元素币十分之一的[余额] 来购买.
英文名:Surfacing a Datsun 240Z with Rhino 3D ( V6 or V5 ) Level 2
教程共61集,总时长13小时35分钟,高清视频,有素材文件。
官方简介:https://www.udemy.com/course/automotive-surfacing-with-rhino-3d/
\01-Introduction.mp4
\02-Topology.mp4
\03-Intersect-Plane-and-IPlane.mp4
\04-Opening-the-File.mp4
\05-Placing-the-first-point-in-3D.mp4
\06-Creating-the-first-section.mp4
\07-Adding-3D-curves.mp4
\08-Building-the-cage-with-3D-curves.mp4
\09-Creating-the-first-surfaces.mp4
\10-Creating-the-hood-surface.mp4
\11-Match-Surface-Observation.mp4
\12-Trimed-Untrimed-and-Extend-Surface.mp4
\13-Set-Points.mp4
\14-The-Side-View-Window.mp4
\15-The-Windscreen.mp4
\16-The-Roof-Top.mp4
\17-The-Roof-Top-part-2.mp4
\18-Improving-the-Side-Window.mp4
\19-Working-on-the-side-panels.mp4
\20-Working-on-the-side-panels-part-2.mp4
\21-Working-on-the-side-panels-part-3.mp4
\22-Working-on-the-side-Panels-part-4.mp4
\23-Working-on-the-side-Panels-part-5.mp4
\24-Working-on-the-side-Panels-part-6.mp4
\25-Trimming-some-surfaces.mp4
\26-Working-on-the-aft-part.mp4
\27-Finishing-the-Headlights.mp4
\28-Resurfacing-part-of-the-headlight-with-Xnurbs.mp4
\29-Projecting-Curves.mp4
\30-Creating-the-headlight-cover.mp4
\31-Adding-the-Lip.mp4
\32-Offsetting-Surfaces.mp4
\33-Grouping-Objects.mp4
\34-Working-on-the-blends-for-the-Wheel-Well.mp4
\35-Working-on-the-Wheel-Well.mp4
\36-Adding-Thicknesses-to-the-wheel-wells.mp4
\37-Working-the-blends.mp4
\38-Checking-and-fine-tuning-Surfaces-before-adding.mp4
\39-Working-on-blends-part-2.mp4
\40-Working-on-blends-part-3.mp4
\41-Reworking-a-few-surfaces-fine-tuning.mp4
\42-Creating-the-Character-line.mp4
\43-Working-on-the-Front-end.mp4
\44-Adding-fillets.mp4
\45-Working-on-the-headlight-cover.mp4
\46-Making-some-adjustments.mp4
\47-Making-the-front-Bumper.mp4
\48-Filleting-the-fuel-Cap.mp4
\49-Adding-Fillets-to-the-door-panel.mp4
\50-Touch-ups-and-details-added.mp4
\51-The-wheel.mp4
\52-The-Tire.mp4
\53-Organizing-your-3D-data-as-grouped-elements.mp4
\54-Using-the-Rhino-Render.mp4
\55-Image-Mapping-logos.mp4
\56-Rendering-with-Vray-part-1.mp4
\57-Rendering-with-Vray-part-2.mp4
\58-Rendering-with-Vray-part-3.mp4
\59-Rendering-with-Vray-part-4.mp4
\60-Rendering-with-Vray-part-5.mp4
\61-Conclusion.mp4
\ressources.zip
¥01-简介.mp4
\02- 拓扑.mp4
\03-相交平面和 I 平面.mp4
\04-打开文件.mp4
\05-在3D中放置第一个点.mp4
\06-创建第一个部分.mp4
\07-添加-3D-曲线.mp4
\08-用3D曲线构建笼子.mp4
\09-创建第一个曲面.mp4
\10-创建引擎盖表面.mp4
\11-匹配-表面观察.mp4
\12-修剪-未修剪-和-延伸-表面.mp4
\13-设定点.mp4
\14 侧视图窗口.mp4
\15-挡风玻璃.mp4
\16-屋顶.mp4
\17-屋顶-顶部-部分-2.mp4
\18-改善侧窗.mp4
\19-在侧面工作面板.mp4
\20-在侧面面板上工作-第2部分.mp4
\21-在侧面面板上工作-第3部分.mp4
\22-在侧面工作-面板-部分-4.mp4
\23-在侧面工作-面板-部分-5.mp4
\24-在侧面工作-面板-部分-6.mp4
\25-修剪某些表面.mp4
\26-在船尾工作.mp4
\27-前大灯.mp4
\28-带Xnurbs的前大灯部分重新铺设.mp4
\29-投影曲线.mp4
\30-创建大灯罩.mp4
\31-添加嘴唇.mp4
\32-对冲表面.mp4
\33-分组对象.mp4
\34-在搅拌机上工作.mp4
\35-在轮上工作.mp4
\36-将厚度添加到轮孔.mp4
\37-混合工作.mp4
\38-添加前检查和微调曲面.mp4
\39-在混合上加工-部分-2.mp4
\40-在混合物上工作-第3部分.mp4
\41-返工-几个-表面-微调.mp4
\42-创建字符行.mp4
\43-在前端工作.mp4
\44-添加圆角.mp4
\45-工作在大灯罩上.mp4
\46-进行一些调整.mp4
\47-制作前保险杠.mp4
\48-燃料盖.mp4
\49-将圆角添加到门板上.mp4
\50-已添加修饰和详细信息.mp4
\51-轮子.mp4
\52-轮胎.mp4
\53-组织您的 3D 数据作为分组元素.mp4
\54-使用犀牛渲染.mp4
\55-图像映射徽标.mp4
\56-渲染-与-Vray-part-1.mp4
\57-渲染-与-Vray-部分-2.mp4
\58-渲染-与-Vray-部分-3.mp4
\59-渲染-与-Vray-部分-4.mp4
\60-渲染-与-Vray-部分-5.mp4
\61-结论.mp4
\资源.zip
参与人数 5 元素币 +74 活跃度 +34
黑了一个度哇
Hawk_Paladin  发表于 2022-11-20 10:48:33
真不错
宗师老Q  发表于 2023-1-12 14:49:40
6666666666666666666666666666666666666666666666
Hawk_Paladin  发表于 2023-12-21 21:33:26
exiazs 实名
动画师
20 小时
阿尔法晶矿 长枪 元素巨无霸 粉晶石 蓝月药水 长剑
