[Unity] unity3d利用MovieTexture来实现视频播放
查看:2496 |回复:5 | 2014-10-11 01:54:26
2013年07月05日 ⁄ Unity3D ⁄ 共 2250字
以前也写过这样的代码,能控制播放暂停,但是功能还不够全面,比如是否要实现循环播放,还有就是停止后播放状态没有改变,就是那个暂停按钮应该变成播放状态。这下把这些都改了,功能算是比较全面了。
public var bofang:boolean = false;
public var movieTexture:MovieTexture;
function Start(){
    try{
        movieTexture.Stop();
        movieTexture.loop = false;
    }catch(e){}
function playMovie(){
    movieTexture.Play();
    yield WaitForSeconds(1);
private var flag01:boolean = true;
private var flag02:boolean = false;
function Update(){
    if(!bofang){
        return;
   if(movieTexture.isPlaying){
      flag02= true;
   }else{
      flag02= false;
   //赋值剪辑到音频源
   //与音频同步播放
   audio.clip  =  movieTexture.audioClip;
   //播放视频和音频
   //movieTexture.loop = false;
   //renderer.material.mainTexture.wrapMode = TextureWrapMode.Clamp;
    if(flag01){
        audio.Play();
    }else{
        movieTexture.Pause();
        audio.Pause();
//加上 播放暂停 关闭
//播放器
private var BFQWidth:float = 1024;
private var BFQHeight:float = 702;
//var BFQTexture:Texture;
//private var BFQGBWidth:float = 16;
//private var BFQGBHeight:float = 15;
//var BFQGBStyle:GUIStyle;
//关闭按钮
//播放器 播放暂停
private var BFQPlayWidth:float = 44;
private var BFQPlayHeight:float = 44;
var BFQPlayStyle:GUIStyle;
//播放按钮
var BFQPauseStyle:GUIStyle;//暂停按钮
function OnGUI(){
    if(!bofang){
       return;
    //GUI.DrawTexture(new Rect(0, 0, BFQWidth, BFQHeight), BFQTexture, ScaleMode.StretchToFill);
    GUI.DrawTexture (Rect (0,60, 1024, 702),movieTexture,ScaleMode.ScaleToFit );
   //movieTexture.Play();
    /*  //关闭按钮
    if(GUI.Button (Rect (980, 23, BFQGBWidth, BFQGBHeight),"",BFQGBStyle)){
        //GameObject.Find("Data").GetComponent("Data").cameraMain.enabled = true;
        //GameObject.Find("Data").GetComponent("Data").cameraView.enabled = false;
        bofang = false;
        guiTexture.texture = null;
        //gameObject.GetComponent("MovieControler").enabled = false;    }
    //播放暂停
    if((!flag01) || (!flag02)){
         if(GUI.Button (Rect (960, 80, BFQPlayWidth, BFQPlayHeight),"",BFQPlayStyle)){
            //Debug.Log(movieTexture.duration.ToString());
            flag01 = true;
             movieTexture.loop = true;
            playMovie();
    }else if(flag01 && (flag02) ){
        if(GUI.Button (Rect (960, 80, BFQPlayWidth, BFQPlayHeight),"",BFQPauseStyle)){
            flag01 = false;
function GuanBi(){
    bofang = false;  guiTexture.texture = null;
//   确保我们有GUI 纹理和音频源 @script  RequireComponent(GUITexture) @script  RequireComponent(AudioSource)
2014-10-11 01:54:26
5个回答,把该问题分享到群,邀请大神一起回答。
元素帖子强,满满正能量!
2018-10-17 09:55:26   回复
这世上没有什么是元素币搞不定的,如果有,那就用更多!
2018-10-17 09:59:28   回复
厉害了厉害厉害  谢楼主分享
2018-10-17 10:08:30   回复
2018-10-17 10:10:43   回复
Unity3D技术手机游戏引擎手游引擎
