(Texturing Realistic Skin for Characters)
This tutorial is an update of my older skin texturing tutorial, with new processes and techniques while using up to date software. I not only show you how to texture the face but also the upper body.
In this tutorial, I will be going over my entire process when it comes to texturing skin for a realistic character. The process is covered in-depth, with every step explained with narration, in real-time. I go over the creation of all the maps I currently use to generate realistic skin.
There is a lot of content in this tutorial, but I have labeled the chapters in a way to make it easy for you to skip ahead or jump to the area which interests you most, without having to watch the entire process. I did this to make sure a beginner has all the information they need, or a more experienced artist can jump to the information they are seeking.
By the end of the tutorial, you should have the knowledge and techniques to apply realistic skin textures to your own characters.
NOTE: I am using resources from Texturing.xyz for both the diffuse and displacement of the skin.
(Lookdev for Realistic Characters)
This tutorial is an update of my older lookdev tutorial, with new processes and techniques while using up to date software. I show you how to lookdev the skin, as well as the props and accessories.
In this tutorial, I will be going over my entire process when it comes to doing Lookdev for a realistic character. The process is covered in-depth, with every step explained with narration, in real-time.
(Xgen for Characters)
This tutorial is an update of my older Xgen tutorial, with more advanced techniques and a much broader variety of different grooms. I will show you multiple techniques to help you achieve a believable groom for your characters.
In this tutorial, I will be going over my entire process when it comes to generating a believable groom for your character. The process is covered in-depth, with every step explained with narration, in real-time.
By the end of the tutorial, you should have the knowledge and techniques to apply realistic grooms to your own characters.
(Texturing Props and Accessories for Characters)
In this tutorial, I will be going over my entire process when it comes to texturing Props and Accessories for your character. The process is covered in-depth, with every step explained with narration, in real-time.
By the end of the tutorial, you should have the knowledge and techniques to apply realistic textures to your characters Props and Accessories.
Gumroad - Barbarian Tutorial by Tom Newbury http://gumroad.com/tomnewbury
