最简单的用法:下流的用法
public class MusicManager : MonoBehaviour
//We make a static variable to our MusicManager instance
public static MusicManager instance { get; private set; }
//When the object awakens, we assign the static variable
void Awake()
instance = this;
public void Play()
//Play some audio!
标准用法
//Here is a private reference only this class can access
private static MusicManager _instance;
//This is the public reference that other classes will use
get
//If _instance hasn't been set yet, we grab it from the scene!
//This will only happen the first time this reference is used.
if(_instance == null)
_instance = GameObject.FindObjectOfType<MusicManager>();
return _instance;
public void Play()
//Play some audio!
完美用法
get
//Tell unity not to destroy this object when loading a new scene!
DontDestroyOnLoad(_instance.gameObject);
return _instance;
void Awake()
//If I am the first instance, make me the Singleton
_instance = this;
DontDestroyOnLoad(this);
else
//If a Singleton already exists and you find
//another reference in scene, destroy it!
if(this != _instance)
Destroy(this.gameObject);
