作者的油管教程,需科学上网 https://www.youtube.com/watch?v=ptNG7LNPQjc&t=1s支持maya任意版本
安装方法:
1. 复制gs_curvetools 文件夹到 我的文档\Maya\xxxx\scripts\
2. 运行Maya
3. 在脚本编辑器的python标签里运行:
import gs_curvetools.init as ct_init;reload(ct_init);ct_init.Init();
全选脚本,鼠标中键拖到工具架上,点击运行
GS CurveTools installation
1. Copy gs_curvetools folder to {PathToDocuments}\Documents\Maya\{MayaVersion}\scripts\
Example of the final folder structure:
Documents\Maya\2019\scripts\gs_curvetools\icons
Documents\Maya\2019\scripts\gs_curvetools\utils
Documents\Maya\2019\scripts\gs_curvetools\__init__.py
Documents\Maya\2019\scripts\gs_curvetools\core.py
Documents\Maya\2019\scripts\gs_curvetools\init.py
Documents\Maya\2019\scripts\gs_curvetools\LICENSE.txt
Documents\Maya\2019\scripts\gs_curvetools\main.mel
Documents\Maya\2019\scripts\gs_curvetools\readme.txt
2. Run Maya
3. Copy and paste this line to "Python" command box and press "Enter":
IMPORTANT: There should be no spaces or tabs before this command!
4. Look for GS tab on your Shelf
5. Click CT UI button to run the menu. Click again to hide the menu.
NOTES:
>> To reset to factory defaults click CT with "refresh" arrow button.
>> To stop all scripts and close the menu press CT DEL button.
>> You can use middle-mouse button drag to move the buttons to any tab.
>> All the hotkeys are available in Hotkey Editor > Custom Scripts > GS > GS_CurveTools.
>> Always repeat initialization steps when updating the plug-in to a new version.
>> You can always repeat initialization steps if you lost control buttons or shelf.
