程序化贴图 [作品参考] Substance Designer 2021.1 (11.1) update summary
1298
文/jplee
主要特点
新的Pantone颜色支持
Main features
​New Pantone Color Support
已在此更新中添加了Pantone专色。
Pantone以图形设计,时装设计和制造行业中使用的各种颜色而闻名。
这项新功能使将材料与真实色彩值匹配变得更加容易。
有关详细信息,请参阅专用手册页。
Pantone spot color has been added in this update.
Pantone is known for a variety of colors used in graphic design, fashion design, and manufacturing industries.
This new feature makes it much easier to match material to real color values.
Please refer to the dedicated manual page for details.
Substance Designer - Spot Colors (Pantone)​
*要使用新的Pantone颜色,必须在首选项中将颜色管理设置设置为Adobe ACE。
* To use the new Pantone color, you must set the color management setting to Adobe ACE in preferences.
在RGB和Pantone颜色之间选择。
拾色器有一个选项可以选择可以编辑颜色的模式。
默认情况下,它设置为RGB,但是您也可以切换到Pantone book(颜色库)。
默认情况下包括几个颜色库。
Choose between RGB and Pantone colors.
Color Picker has an option to select the mode in which you can edit colors.
By default it is set to RGB, but you can also switch to Pantone book (color library).
Several color libraries are included by default.
更改颜色选择器模式时,可用的颜色由所选的Pantone书定义。
When the color picker mode is changed, the available colors are defined by the selected Pantone book.
*在Pantone书中搜索颜色
您可以使用列表顶部的文本字段在Pantone Book中搜索特定颜色。
我们不会研究其他书籍,因此,当您找到其他书籍时,请不要忘记切换到其他书籍。
* Search colors in Pantone book
You can use the text field at the top of the list to search for a specific color in the Pantone Book.
We don't look into other books, so don't forget to switch to other books when you find them.
*使用选择器找到正确的颜色
从颜色选择器中选择要在屏幕上显示的颜色,您将在当前的Pantone Book中找到最匹配的颜色。
* Use the picker to find the right color
Select the color you want on the screen from the color picker and you will find the best matching color in the current Pantone Book.
新的禁用节点(禁用节点)
New disable node (disable node)
在此版本中,已添加了禁用节点的功能。
当您要比较和迭代材质以查看特定节点对最终结果产生的影响时,此功能很有用。
要禁用节点,请右键单击该节点,然后选择“禁用选择”或按快捷键。
按Shift + D。
这取决于条件,但并非所有节点都可以禁用。
In this version, the ability to disable nodes has been added.
This feature is useful when you want to compare and iterate in a material to see what effect a particular node adds to the final result.
To disable a node, right-click on the node and choose Disable Selection or press the shortcut key.
Press Shift+D.
It depends on the criteria, but not all nodes can be disabled.
有关更多信息,请参考下面文档页面的专用部分。
For more information, please refer to the dedicated section of the documentation page below.
Substance Designer - The Graph view
The Graph view
视口细分网格输出功能
Viewport tessellation mesh export function
现在可以将3D视图中的镶嵌网格物体导出为多种文件格式。
Tesselated meshes in 3D views can now be exported to several file formats.
在3D视图中,只需使用“文件”>“导出”场景。In the 3D view, simply use File> Export scene.
有关详细信息,请参阅下面的文档页面的专用部分。
Please refer to the dedicated section of the documentation page below for details.
Substance Designer - 3D View
3D View : The 3D View helps you view and understand your materials with custom meshes and rendered PBR materials.
docs.substance3d.com​
总体改进
General improvements
在此版本中,添加了一些小功能但有用的改进和新功能来帮助您正常开展业务。
*引擎自动内存分配
该程序的RAM和VRAM管理已得到改进,现在可以更好地适应可用的系统内存。
现在,具有大量VRAM的GPU可以进一步利用板载内存。
*现在3D视图支持新的“物理尺寸”语义。
自定义着色器现在可以调整其行为,以考虑材质的物理尺寸。
有关更多信息,请参见应用程序随附的着色器。
In this version, some small sutff but useful improvements and new features have been added to help you with your normal business.
*Automatic memory allocation for engine
The program's RAM and VRAM management has been improved and now adapts better to the available system memory.
GPUs with a lot of VRAM can now utilize the onboard memory even more.
*Now 3D View supports a new "physical size" semantics.
Custom shaders can now adjust their behavior to take into account the physical size of the material.
See the shaders provided with the application for more information.
*新设置可从库中排除内容
库现在可以排除特定的文件扩展名,特定的名称模式
这使您可以从库窗口中排除不需要的内容。
*导出位图时创建文件夹
从图形导出位图时,可以在没有文件夹和子文件夹的情况下指定斜杠来创建位图。
*New setting to exclude content from library
Libraries can now exclude specific file extensions, specific name patterns
This allows you to exclude unwanted content from the library window.
* Create folder when exporting bitmap
When exporting a bitmap from a graph, you can specify a slash to create it when there are no folders and subfolders.
您可以使用project / $(graph)/ $(identifier)在自己的文件夹中组织每个图的位图。You can use project/$(graph)/$(identifier) to organize bitmaps per graph in your own folder.
* SBS渲染器支持Adobe ACE和ICC配置文件。
使用Adobe ACE引擎时,SBS渲染过程(自动化工具包的一部分)可以使用适当的颜色管理来渲染物质输出。*SBS renderer supports Adobe ACE and ICC profiles.
The SBS Render process (part of the Automation Toolkit) can render the Substance output with proper color management when using the Adobe ACE engine.
END
天若有情天亦老, 人间正道是沧桑。
毒游小行家 实名
吸鼠霸王
2998 小时
翡翠剑 【绝】红龙战甲 英雄盾 铁剑 钢盾 钢剑 长剑 元素铜币 元素银币 元素金币 短杖 【绝】珍珠戒指 【绝】黄金项链 碧之轨迹 长枪 魔神战甲 裁决 火元素 赤色药水 紫色药水 钢铁矿镐 彗星钛晶矿 阿尔法晶矿 守望者【EX】 希望人没事 振金项链 满天星 黑珍珠戒指 玫瑰金项链 烈-红龙战甲 无色原始矿 绿母翠晶矿 粒粒皆辛苦
