--------熔炉4 Amplify Color
174
价格:30元素币(或3余额) 百度网盘 销售总额:90元素币 购买人数:3
尊敬的游客 ,本内容需要支付 30元素币十分之一的[余额] 来购买.
Requires Unity 3.5.7 or higher.
NEW! Support for Unity 5.6Amplify Color is the lightest, most flexible, Unity Extension for Industry Level Color Grading. Easy to use and to integrate into your project, no coding required and works well for both 3D and 2D games.
Define and blend LUTs (color profiles) between different areas, smooth and 100% Artist Friendly. Volumes may be scaled, moved, rotated and even animated. A flexible tool that will allow you to create stunning environments in no time.
The plugin can connect directly to Photoshop, or can also be used manually with similar tools like After Effects, Nuke and others. Use the software already in your pipeline to push color transformations directly into your Unity Project Scenes.
Supports All Platforms
Optimized for MobileUsing your favorite editor you may alter the contrast, color curves, exposure, saturation, hue and more, or a combination of all transforms at once.
Not only will you be able to switch or blend between color profiles, you can even use a static Texture or a dynamic Render Texture as a mask to exclude certain areas.
• Industry level color grading
• High-performance and Mobile-ready
• Semi-automated Photoshop Workflow
• File-based mode for other Image Editors
• Dynamic blending between profiles
• Texture-based per-pixel masking
• All Color Alterations Supported
• Oculus/VR friendly
• Color Volumes
• Third-party Effects Volume Blending
• Base and Volume LUT mixing
• Complete source-code
• NEW! 2D Color Volumes
• NEW! Depth-based Masking
• NEW! HDR Tone Mapping
• NEW! HDR Dithering
• NEW! Broader mobile device support
• NEW! Improved tools
Take the WebPlayer Demo for a spin
Learn More at the Official Forum Thread
Make the change, use the professional tools you crave. Our products are developed by industry professionals and our support team always goes one step beyond to resolve any possible issues our clients might have.
Get in touch, we would love to hear your story, help promote and feature your work.
wanggilbert 实名
49 小时
长枪 火元素
