import System.IO;
//combine by shenmifangke
class ReplaceSplatmap extends ScriptableWizard
var Splatmap: Texture2D;
var New : Texture2D;
var FlipVertical : boolean;
function OnWizardUpdate(){
helpString = "Replace the existing splatmap of your terrain with a new one.\nDrag the embedded splatmap texture of your terrain to the 'Splatmap box'.\nThen drag the replacement splatmap texture to the 'New' box\nThen hit 'Replace'.";
isValid = (Splatmap != null) && (New != null);
function OnWizardCreate () {
if (New.format != TextureFormat.ARGB32 && New.format != TextureFormat.RGB24) {
EditorUtility.DisplayDialog("Wrong format", "Splatmap must be converted to ARGB 32 bit format.\nMake sure the type is Advanced and set the format!", "Cancel");
return;
var w = New.width;
if (Mathf.ClosestPowerOfTwo(w) != w) {
EditorUtility.DisplayDialog("Wrong size", "Splatmap width and height must be a power of two!", "Cancel");
return;
try {
var pixels = New.GetPixels();
if (FlipVertical) {
var h = w; // always square in unity
for (var y = 0; y < h/2; y++) {
var otherY = h - y - 1;
for (var x = 0; x < w; x++) {
var swapval = pixels[y*w + x];
pixels[y*w + x] = pixels[otherY*w + x];
pixels[otherY*w + x] = swapval;
Splatmap.Resize (New.width, New.height, New.format, true);
Splatmap.SetPixels (pixels);
Splatmap.Apply();
catch (err) {
EditorUtility.DisplayDialog("Not readable", "The 'New' splatmap must be readable. Make sure the type is Advanced and enable read/write and try again!", "Cancel");
return;
//http://blog.csdn.net/shenmifangke
@MenuItem("Terrain/Replace Splatmap...")
static function Replace (){
ScriptableWizard.DisplayWizard(
"ReplaceSplatmap", ReplaceSplatmap, "Replace");
@MenuItem("Terrain/Export Texture")
static function Apply()
var texture : Texture2D = Selection.activeObject as Texture2D;
if (texture == null)
EditorUtility.DisplayDialog("Select Texture", "You Must Select a Texture first!", "Ok");
return;
