E.J. Hassenfratz是一位屡获艾美奖的自由动态设计师,同时也是著名的C4D教育专家。毕业于宾州滑石大学并曾任职于ABC(美国广播公司),服务过包括NBA、 NHL、ESPN和Discovery探索频道等在内的客户。他是一位自学成才的3D艺术家,因此热心于教育事业,之后创建了著名的个人教育品牌网站eyedesyn.com,发布过大量C4D相关教程并广为国内C4D用户所熟知,常年作为Maxon特邀的演讲嘉宾在各大CG展会上进行技术分享,现已加入School of Motion。
=============教程目录结构============
1. Introduction
01 Cinema 4D Weekly
2. Cinema 4D Weekly
01 Text inflation animations
02 Intro to Morph deformer
03 Intro to subsurface scattering in Cinema 4D (C4D)
04 Subsurface scattering in OctaneRender
05 Intro to Cinema 4D R20 fields
06 Intro to R20 volumes
07 Intro to decay and delay fields in R20
08 Mesh morphs with fields and volumes
09 Creating material wipes using fields
10 Interactive render region for OctaneRender
11 Viewing the speed graph in C4D
12 Creating realistic noise-based materials
13 Follow-through and overlapping animation
14 Procedural growth animation
15 Rigging and animating a 3D character in minutes with Mixamo
16 Easy melt simulations in C4D
17 Fading objects with effectors
18 Onion skinning in C4D
19 Blueprint renders using Sketch and Toon
20 Baking Mixamo animation into motion clips
21 Mixing Mixamo animation with motion xlips
22 Must-know Xpresso
23 Looping animation applied to effectors
24 Intro to C4D sculpting tools
25 Creating glTF files for AR and VR
26 Intro to IK rigging
27 Intro to rigging with joints
28 Using deformers for character animation
29 Rigging simple objects with FFDs
30 Animation smears
31 Cartoon mouth rig using Spline IK
32 Add watermarks or timecodes to renders
33 Intro to the Doodle tool
34 Faster renders using Physical Renderer
35 Using bendy limbs rig for C4D
36 Automatic walk cycles using CMotion
37 Rigging mouth using clusters
38 Cartoon eyeball rig
39 Intro to IK dynamics
40 Worfklow enhancers - selection object
41 Creating clay renders
42 Three ways to animate splines
43 Selecting every other clone or polygon
44 Blending Mixamo motion capture animation
45 Using pivot objects and Mixamo motion capture
46 Model a cartoon hand
47 Introduction to collision deformer
48 Using connectors and dynamics
49 Dynamic connections between objects
50 Creating a dynamic spring rig
51 Triggering cloth dynamics
52 Model faster with Tweak mode
53 Paint objects onto a surface
54 Text inflation animations
55 Intro to Morph deformer
56 Intro to subsurface scattering in Cinema 4D (C4D)
57 Subsurface scattering in OctaneRender
58 Intro to C4D sculpting tools
59 Making Symmetrical and Radial Polygon Selections
60 Rendering Caustics in Redshift
61 Creating an iridescent metal shader in Redshift
62 Timeline Workflow Tips
63 Painting worn edges with vertex maps
64 Speeding up your animation workflow with timeline markers
65 How to sculpt cloth wrinkles using deformers
66 How to draw splines on a surface
67 Real-time cartoon outlines in the viewport
68 Workflow enhancer - Interaction tag
69 Tips for fixing jittery dynamics
70 5 C4D preferences you absolutely should change
71 Rigging splines with IK-spline
72 Tips for better sketch and toon renders
73 Using the Cinema 4D color wheel to easily create color harmonies
74 Easily edit Mixamo animations using motion layers
75 How to easily select anything in your viewport
76 Create a squash and stretch rig using joints
77 Using color swatches in Cinema 4D
78 Using gobos in Redshift
79 Make your splines and points easier to see with this setting
80 How to easily select anything in your viewport
81 Intro to alembic workflows
82 Fixing bad weighting using Delta Mush
83 Creating Dolly and Zoom camera moves in C4D
