程序化贴图 [sbs格式] STW Mirror Plus - Advanced MirrorExtrusion Tool for SD-Indie高级镜像挤出工具
5012
11
本资源为:Indie (SBS + SBSAR); Unlimited Seats
价格:360元素币(或36余额) 百度网盘 销售总额:2880元素币 购买人数:8
尊敬的游客 ,本内容需要支付 360元素币十分之一的[余额] 来购买.
    内容
STW镜像加SBSAR
STW镜像加SBS
SBS文件及其示例
对称灰度SBS
With this node you can create complex shapes and elements for hard surface or ornamental materials in just a few steps.
The node has two modes: mirror and extrusion. In mirror mode you can just mirror like normal or create an extrusion in the middle around the mirror axis. You have options for scaling, offsets and skews to create variation.
In extrusion mode you can just extrude a shape along x or y axis without the mirror effect.
The node uses pixel processor so it's quite fast.
Please read my accompanying blog to see if the node could be useful for you: Here
Two variants of the product are available. The cheaper one contains only the sbsar file!
Contents:
  • STW Mirror Plus SBSAR
  • SBS file with examples
  • Symmetry Greyscale SBS (free bonus)
  • Works with Substance Designer 2018.3.0 and up.
Digital products are non refundable.
Release Notes
No file updates.
  • Changed licenses to Personal, Indie and Studio
  • Studio License is newly added
使用此节点,您只需几步就可以为硬表面或装饰材料创建复杂的形状和元素。
节点有两种模式:镜像和拉伸。在镜像模式下,你可以像镜子一样正常,或者在镜子轴的中间创造一个挤压。您可以选择缩放、偏移和倾斜来创建变化。
在拉伸模式下,可以仅沿x或y轴拉伸形状,而不使用镜像效果。
节点使用像素处理器,因此速度非常快。
参与人数 3 元素币 +8 活跃度 +50
Helinzhou  发表于 2021-11-18 20:59:42
主要就用了镜像和拉伸两个节点吧
水木神川  发表于 2021-11-19 15:57:06
资源发布哪家强?元素首发称大王
漫道  发表于 2021-11-20 18:49:24
鱼煲砸  发表于 2022-5-30 13:55:35
666666666
失落  发表于 2023-4-11 10:16:59
每天一早上元素,挖矿撩妹两不误
hicrazy 实名
16 小时
长剑 长枪
